Recommended settings for NVIDIA control panel?
400 (0.13/day)
System Name Core p90
Processor I7 9700k
Motherboard ASRock Z390 Phantom Gaming 4
Cooling Ek supremacy evo cpu block/nexxxos ut60 rad 480mm/D5 vario pump 310mm reservoir combo.
Memory Trident gskill 4x8gb 3000mhz (temporarily running 2x 32gb ddr4 corsair vengeance 3600mhz)
Video Card(s) Nvidia Founders edition rtx 3080 10gb
Storage M.2 Intel 660p 1024gb, 4tb 7200 rpm black Western Digital hdd
Display(s) Acer x34 predator 3440x1440p 120hz g-sync ultrawide 21:9 monitor
Case Thermaltake Core P90 tempered glass edition
Audio Device(s) On board
Power Supply Thermaltake smart m1200w
Mouse Razer Basilisk v3
Keyboard Logitech G910
Software Windows 10 64bit
I'm looking for recommendations as to what settings to put for a gtx 2080 ti in the nvidia control panel. Some of the settings I'm not sure about:
"quality vs performance" in the "image settings with preview" tab
"ultra low latency" vs "low" vs "off"
"pre-rendered frames" 1 or 2 or 3 ... ?
"texture" settings? negative lod bias etc...
also would like to know for color settings in the panel, do you have it set to "set by the video player" or "nvidia controlled" ?
1,459 (0.60/day)
Auto. No need to change anything, it might give you slight benefit in some games but in others it'll create problematic performance issues such as micro stuttering. With auto presets the driver will scale well with games across the board
4,926 (0.79/day)
Multidimensional
System Name Intel NUC 12 Extreme
Processor Intel Core i7 12700 (E Cores Disabled)
Motherboard Intel NUC Module Motherboard
Cooling NUC Blower Cooler + 3 x 92mm Fans
Memory 64GB Corsair 3200Mhz CL22
Video Card(s) PowerColor RX 9070 16GB Reaper
Storage Silicon 512GB Gen4 SSD + 256GB SD Card
Display(s) Sony 4K Bravia X85J 43Inch TV 120Hz
Case Intel NUC 12 Extreme Mini ITX Case
Audio Device(s) Realtek Audio + Dolby Atmos
Power Supply SFX FSP 650 Gold Rated PSU
Mouse Logitech G203 Lightsync Mouse
Keyboard Red Dragon K552W RGB White KB.
VR HMD ( ◔ ʖ̯ ◔ )
Software Windows 10 Home 64bit
Benchmark Scores None. I also own a Apple Macbook Air M2
Best to test the settings out for yourself otherwise just leave it auto but here are my settings...
Manage 3D Settings
- Low Latency Mode - Ultra
- Texture Filtering Negative LOD bias - Clamp
- Texture Filtering Quality - High Quality
Configure Surround, PhysX
- PhysX Settings - Your Video Card (RTX 2080ti)
Adjust Desktop Color Settings
Digital Vibrance - 65% - 70%
That's pretty much it, like I said test some settings out for yourself.
