Red light on boot
Connor Satchell
4 (0.00/day)
Hello, I need help. Me and my mum built a pc and it was working fine for about a month and it stopped booting up and came up with a red light, we were told it was the cpu so we sent it off to be checked by amd and they said it was faulty so hey send up a new one. When it came we had the same problems so we asked and amd asked to see the motherboard so we sent it over and today we received a replacement for our motherboard and cpu but still a red light. Does anyone know what’s going on? Please help.
What board, what cpu for starters.
You could list the full specs please.
Next question: Which LED lights up, as there is a series of them to indicate the boot sequence.
As per the Asus site:
ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
If you remove all the RAM does the Motherboard emit a constant beeping to indicate a RAM error?
Are both the 24 pin main cable and 4 or 8 pin CPU cable inserted all the way?
You might have to remove the Motherboard and assemble on a non conductive surface for testing, something like a sheet of cardboard or a wooden chopping board etc, this will also give you the chance to check for any extra standoffs under the Motherboard that may be causing a short.
so I’ve taken out the ram tried to turn it on and it just did the same thing and all the cables are in all the way
plz give us all the specs so we can help better \ easier - thx - like tigger said
power supply + graphiccard + ram \how much in which slots and what speed?
