Reducing fan noise
6,560 (1.01/day)
System Name Vintage
Processor i7 - 3770K @ Stock
Cooling Scythe Zipang II
Memory 2x4GB Crucial DDR3
Video Card(s) MSI GTX970
Storage M4 124GB SSD// WD Black 640GB// WD Black 1TB//Samsung F3 1.5TB
Display(s) Samsung SM223BW 21.6"
Case Generic
Power Supply Corsair HX 520W
Software Windows 7
Ok so i just got this case up and running and it has:
1x 120mm front fan (in)
1x 120mm side fan (in)
1x 80mm side fan (in)
1x 80mm rear (out)
plus PSU, GPU fan and CPU fan of course
and the problem is its just so loud!
How can i reduce this noise so i don't get kept awake by it
sneekypeet
not-so supermod
29,711 (4.27/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
Either mod them to use less voltage(= less noise), or swap em out for lower db fans all together.
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
Yes, if they are running at full blast than not much you can do other than regulate the speed by controlling the voltage. If you have them hooked to your motherboard, you may be able to do it via software.
One other thing that helps in certain situations is putting a dampening between the fan and case (like a rubber gasket or grommets). I do that with all of my fans.
Then there is simply getting better fans - higher CFM, lower dB.
2,201 (0.35/day)
System Name Ryzen7700
Processor AMD Ryzen 7 7700
Motherboard Asus ROG STRIX B650E-F GAMING WIFI
Cooling NZXT Kraken X62
Memory Patriot Viper Venom PVV532G700C32K (32GB @ 6000CL28)
Video Card(s) AMD Radeon RX 6800XT Midnight Black
1x 80mm rear (out)
If you can get the fan's to run at 1000 rpm, you will find this very quiet. You can do this by setting the fan speeds in the bios (if possible), otherwise you can set them with speedfan if you motherbord supports this. (http://www.almico.com/speedfan.php)
6,560 (1.01/day)
System Name Vintage
Case Generic
Software Windows 7
hmm, looking at a reducing a voltage how to page now, looks like it may be ok. I know i am going to get rid off the 80mm side fan for a start - i don't need that at all. That should reduce some noise.
unfortunately they are all linked directly to the PSU so they will all go full pelt.
1,172 (0.18/day)
UK
Processor Intel Core 2 Duo E7200 3.40GHz (400x8.5)
Motherboard Gigabyte GA-EP45-UD3P Rev 1.1
Cooling Xigmatek HDT-S1283
Memory 2x Crucial Ballistix DDR2 2GB 4:5 @ 500MHz 5-5-5-15
Video Card(s) Asus GTX 560Ti 1GB TOP Edition
Storage Crucial M4 128GB SSD + WD Black 500GB WD5001AALS
Display(s) Samsung P2370HD @ 1920x1080 60Hz
Case Antec 300
Audio Device(s) Soundblaster Live! 24-bit w/ Creative Inspire T6060 5.1 200W
Power Supply CoolerMaster Silent Pro Gold 600w
Software Windows 7 Professional Edition SP1 64-bit
i had a similar prob with fan noise, i had
120mm (front-in)
80mm (side-out)
80mm (back-out)
plus gpu and cpu
so the first thing was i 7v modded every fan, this was a big jump towards silence. 2nd, removed the rear fan as its useless, got a freezer 7 pro and accelero s1 for gpu...now its shhh
6,560 (1.01/day)
System Name Vintage
Case Generic
Software Windows 7
120mm (front-in)
80mm (side-out)
80mm (back-out)
plus gpu and cpu
practising the 7V trick on a bit of fan cable i have kicking around
need a small screw driver by the looks of it though
