Remove Hypersli?
christer6788
8 (0.00/day)
I am really exhausted from trying to make this work with my rig. It works for one game not for another. Then it will start BSOD after the game has been running for days. How can I remove Hypersli? I did a complete reformat and flashed my BIOS and it still shows on startup. There is only one partition on my hardrive how can there be 2 OS? HELP!!!
Gigabyte 970A-D3
AMD FX 8150 Bulldozer WC
2 X GTX 560TIs
16 gb Kingston HyperX
Just run HyperSLI and press uninstall, should do the trick
If you reformatted and it still shows up, either:
1. You aren't sure what reformatted means.
2. You think you reformatted but you really didn't.
3. You accidentally installed HSLI without thinking about it.
4. HSLI is haunting you inter-dimensionally.
:roll:
That right there has made my day LOL. Thank-you
