Replace Tuniq fan with..... ?
1,193 (0.18/day)
Bellevue, WA
System Name 0BL1V10N
Processor Intel Core i7 11700K @ 5.1GHz all-core turbo
Motherboard ASRock Z590 Taichi
Cooling Cooler Master MasterLiquid 360 (with stock CM fans), 12x Pccooler Moonlight Series ARGB 120mm fans
Memory (4x16GB) 64GB Mushkin Redline Lumina 3600MHz 16-19-19-39 XMP
Video Card(s) MSI RTX 4090 SUPRIM LIQUID 24G (not using stock fans) (+150MHz core, +1000MHz memory)
Storage Western Digital Black SN850X 2TB Gen4 NVMe
Display(s) 1x Alienware AW3821DW (3840x1600@144Hz), 2x Dell SE2717H (1080p@75Hz)
Case Phanteks Enthoo 719 Anthracite Grey
Audio Device(s) Schiit Modius + Drop THX AAA 789 + Custom Planar Magnetic Headphones
Power Supply Thermaltake Toughpower GF3 1200W (12VHPWR)
Mouse Logitech G502 X Plus
Keyboard Too many custom mechanical builds to list...
Software Windows 10 Pro 22H2
I got a Tuniq Tower, the one with the LED fan, and well it sucks. The fan is noisy and moves an okay amount of air but the thing I hate the most is the speed knob mine came with is buggy, it doesn't always work, so I need a new fan.
Someone suggested a Silverstone FM121 to me, but I wanted to see if anyone else has replace fans on their Tuniqs and with what. Also what is the main difference between the FM121 and 123?
Oh and quietness at low to mid speeds is *important* but I don't mind it being loud when I crank it up, cause I only do that when playing games anyways.
I would go with a Noctua 120 mm or a Nexus real silent fan. The Nexus real silents fans are extremely quiet yet push a decent amount of air. You could also go with a Papst 120 mm fan some of them are quite good and push a decent amount of air compared to their noise emission.
I'm hoping to get a fan that moves more than say... 60cfm, my current Tuniq says it does about 40 but I'd say its more as it easily beats my Apevia's out and they are rated for 50cfm or something.
I've heard the Nocturas are kind of inefficient for the amount of air they move per the noise they make.
heatsink
fans
pair those up pos with 2 fans and you will be as cools as you can get with air cooling.
