replacing screen on a toshiba with an hp screen?
704 (0.10/day)
Chicago
System Name Woot
Processor AMD FX-9590
Motherboard ASUSTeK m5a99fxpro r2.0
Cooling Corsair H100i gtx
Memory 24GB G.SKILL PC3-12800
Video Card(s) MSI GTX 970GTX
Storage 2X 256GB SANDISK SSD 3X1TB MIXED HD
Display(s) 2x 32" Sony LCD
Case CoolerMaster Storm Trooper
Audio Device(s) 5.1 Surround Onboard
Power Supply Corsair 750W
Mouse Junk
Keyboard Junk
Benchmark Scores Anti-Gigabyte rig!
i got a dv5-1125nr with a bad mobo. i found a toshiba l305-s5915 with a broken lcd on craigslist for $50. will the lcd from the hp work in the toshiba? according to these two links:
http://www.best-laptop-screen.com/1...ml?_mark_=S1&zenid=g8sqfqa3rstkc0n1kbt61sq9p2
and
http://www.ebay.com/itm/LAPTOP-LCD-...Laptop_Screens_LCD_Panels&hash=item4d0adcc0d1
they are both
Data connector:30 pins
Screen Size:15.4 inches
Backlight Lamp:1 CCFL
Resolution:1280*800 pixels
Screen Type:TFT Active Matrix Glossy
W1zzard
Administrator
28,606 (3.74/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
most probably it won't
12,062 (2.54/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
30 pin connectors are in different places, the Toshiba screen is a couple of mm thicker, and the screws are in slightly different places. HP's also tend to be a different size in terms of outer casing.
724 (0.14/day)
St. Louis, MO
System Name Desktop
Processor AMD Ryzen 7800X3D
Motherboard MSI X670E MEG ACE
Cooling Corsair XC7 Block / Corsair XG7 Block EK 360PE Radiator EK 120XE Radiator 8x EK Vadar Furious Fans
Memory 64GB TeamGroup T-Create Expert DDR5-6000
Video Card(s) MSI RTX 4090 Gaming X Trio
Storage 1TB WD Black SN850 / 4TB Inland Premium / 8TB WD Black HDD
Display(s) Alienware AW3821DW / ASUS TUF VG279QM
Case Lian-Li Dynamic 011 XL ROG
Audio Device(s) Razer Nommo Pro Speakers / Audio-Technica ATH-R70X
Power Supply EVGA P2 1200W Platinum
Mouse Razer Viper
Keyboard Razer Huntsman Elite
I can let you know if they are interchangeable.
I need the serial numbers off the two laptops if you can. I can cross reference them with our generic screens.
I have a 15" screen we stock that works on about 70% of laptops unless it is some weird or older connector.
