Resize image to fit screen with 5700 and Adrenaline driver
1,246 (0.19/day)
Repentigny, QC, CANADA
System Name CTG Computer
Motherboard Asrock B650M PRO RS WIFI
Cooling Thermalright PA120 SE
Memory 2x 16gb G.SKILL F5-6000J3038F16GX2-FX5
Video Card(s) Gigabyte RTX 4060
Storage WD Black SN850X 2TB
Display(s) MAG274QRF-QD | Asus vg248qe
Case SAMA IM01
Audio Device(s) Creative SoundBlasterx G6
Power Supply Corsair SF750
Mouse Logitech G pro Wireless
Keyboard Corsair Strafe RGB MK2
Software Windows 11 Pro x64
Hey guys,
Didn't realized, but with my MSI MAG27C and my 5700, I am loosing pixel on the top of my screen. I do not have this issue with my secondary monitor (ASUS vg248qe). I know that before, there was an option to resize the screen, but can't find a way with those new driver.
Anyone already had this issue? and how you fixed this?
The only thing I can think of without screenshots or more information is change the underscan/overscan. I think that used to be in the Display area of Catalyst/Adrenaline.
See attachment
The 2 first is on my MSI
2 other is on the Asus
As you can seee,on the MSI, on the top, there is missing pixel, like if the size is too big.
I can'T find the overscan settings... Using display port cable for each monitor
EDIT
Well, found out something, been like a couple of days before I post. Disabling Freesync remove the overscan...
Did you try Auto function in the monitor OSD?
for aspect ratio? Yes, Tried auto and 16:9, does the same thing. :(
If you use an HDMI cable, open radeon settings and then: settings->display->HDMI scaling might be your solution.
Auto for align the display. In past my monitor for some unknown reason shifted to left. Pressing the Auto fixed it.
It may be named differently for your monitor Like Auto Adjust or Auto Alignment. If there is non then reset the monitor.
I have no auto osd in this msi monitor. I can do a reset, but thats all.
Using display port, no hdmi
