retro gaming PSU?
W
wahdangun
i recently buy several part for build some retro gaming PC
the spec is :
AMD 3000+ 754
mother board SIS (don't know the chipset)
HDD 80 GB WDC
VGA Ati radeon 9800 PRO
and 300 watt PSU
so is the PSU sufficient for this retro, gaming PC ?
WarEagleAU
Bird of Prey
10,812 (1.57/day)
Gurley, AL
System Name Pandemic 2020
Processor AMD Ryzen 5 "Gen 2" 2600X
Motherboard AsRock X470 Killer Promontory
Cooling CoolerMaster 240 RGB Master Cooler (Newegg Eggxpert)
Memory 32 GB Geil EVO Portenza DDR4 3200 MHz
Video Card(s) ASUS Radeon RX 580 DirectX 12 DUAL-RX580-O8G 8GB 256-Bit GDDR5 HDCP Ready CrossFireX Support Video C
Storage WD 250 M.2, Corsair P500 M.2, OCZ Trion 500, WD Black 1TB, Assorted others.
Display(s) ASUS MG24UQ Gaming Monitor - 23.6" 4K UHD (3840x2160) , IPS, Adaptive Sync, DisplayWidget
Case Fractal Define R6 C
Audio Device(s) Realtek 5.1 Onboard
Power Supply Corsair RMX 850 Platinum PSU (Newegg Eggxpert)
Mouse Razer Death Adder
Keyboard Corsair K95 Mechanical & Corsair K65 Wired, Wireless, Bluetooth)
Id say yeah but with the new 400 - 500W out there Id go with one of those.
W
wahdangun
but i only have that PSU, i hope the PSu can handle it
236 (0.04/day)
Jersey Shore
System Name Everyday driver
Processor AMD Phenom II X4 965 Black Edition
Motherboard Asrock 870 Extreme3
Cooling Xigmatek Prime SD1484
Memory 4x GSkill 4GB DDR3 1866
Video Card(s) EVGA GTX 780ti
Storage 2x WD Black 640GB RAID 0
Display(s) Samsung 245BW 1920x1200
Case Antec 900
Audio Device(s) on board
Power Supply Corsair TX-850
Software Windows 7 Home Premium 64 SP1
You should try an online power supply calculator. I used the NewEgg one and it put the your systems power consumption at 273W which is way to close the the max that your PSU can supply. You should try and get an Antec or Corsair 400W-500W PSU.
Power Supply Calculator
OneMoar
There is Always Moar
8,837 (1.61/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
a 250 wat psu will run that
300 is overkill :p
Duffman
1,011 (0.16/day)
Mt. Pocono, PA
System Name Black Knight
Processor Intel Xeon W3520 @4.2Ghz
Motherboard evga Classified 760
Cooling Prolimatech Mega Shadow with Dual Noctua NF-P12 fans
Memory 6GB Corsair Dominator GT DDR3 (3gb x 2) 1600
Video Card(s) Sapphire 5870 Vapor-X
Storage Corsair P128 SSD for OS, 4 Samsung 500GB in RAID10 For Storage
Display(s) Samsung SyncMaster T240HD
Case Corsair Obsidian 800d Twin Zalman ZM-MFC Plus fan controllers
Audio Device(s) HT|OMEGA CLARO
Power Supply Antec Truepower 1000
Software Win7 64bit ultimate
what are u planning to play on this rig?
wolf
Better Than Native
8,672 (1.32/day)
System Name MightyX
Processor Ryzen 9800X3D
Motherboard Gigabyte B650I AX
Cooling Scythe Fuma 2
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
I agree with the advice of a new PSU, the older 300w one has probably degraded and is most likely not that efficient anyway, and if that calculator is anything to go by and we say your system will at least draw say 220w+, I wouldn't do it.
Grab any brand name PSU (corsair, enermax, thermaltake, antec, zalman, etc) that is 400w+ and you'll be fine, they should be quite cheap.
W
wahdangun
i'm planing to play older game, because when 9800pro out i don't have the chance to buy it, and when i saw one for sale, i just buy it. so i ended buying whole retro PC. but the problem is i don't hace any money left.
so should i wait or the psu is ok until i can buy it?
phenomenon1991
27 (0.01/day)
Croatia
System Name Brijeski-PC
Processor AMD Athlon LE-1640 2.70 ghz
Memory 2GB
Video Card(s) Sapphire Radeon HD 4650 1GB DDR2
Storage WD 250GB
Display(s) BENQ V772
Software Windows 7 Ultimate 32 bit
Hi, it's good idea to buy a retro PC
some will think that's not good idea, but you'll need it some day,
and that retro PC will be your precious PC,
but for playing older games, it's a machine ;))
43,629 (6.36/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
the spec is :
AMD 3000+ 754
HDD 80 GB WDC
and 300 watt PSU
It's fine. No problem at all. I run almost those exact specs at work with a sub-300 watt PSU.
Obsidian86
16 (0.00/day)
so far south you wouldn't understand
newer psu's will have trouble powering that since the older psu's had a heavier 5v and 3v rail then the newer specs higher 12v rails but if worst comes to worst the zippy emacs 300 watts will be perfect
