ROG motherboard differences
1,503 (0.37/day)
Processor 11900K
Motherboard ASRock Z590 OC Formula
Cooling Noctua NH-D15 using 2x140mm 3000RPM industrial Noctuas
Memory G. Skill Trident Z 2x16GB 3600MHz
Video Card(s) eVGA RTX 3090 FTW3
Storage 2TB Crucial P5 Plus
Display(s) 1st: LG GR83Q-B 1440p 27in 240Hz / 2nd: Lenovo y27g 1080p 27in 144Hz
Case Lian Li Lancool MESH II RGB (I removed the RGB)
Power Supply Seasonic Prime 850 TX
Mouse Glorious Model D
Keyboard Glorious MMK2 65% Lynx MX switches
Software Win10 Pro
8,570 (1.81/day)
Ovronnaz, Wallis, Switzerland
System Name main/SFFHTPCARGH!(tm)/Xiaomi Mi TV Stick/Samsung Galaxy S25/Ally
Processor Ryzen 7 5800X3D/i7-3770/S905X/Snapdragon 8 Elite/Ryzen Z1 Extreme
Memory 64gb DDR4 3600/8gb DDR3 1600/2gbLPDDR3/12gbLPDDR5x/16gb(10 sys)LPDDR5 6400
Video Card(s) Hellhound Spectral White RX 7900 XTX 24gb/GT 730/Mali 450MP5/Adreno 830/Radeon 780M 6gb LPDDR5
Storage 250gb870EVO/500gb860EVO/2tbSandisk/NVMe2tb+1tb/4tbextreme V2/1TB Arion/500gb/8gb/512gb/4tb SN850X
Display(s) X58222 32" 2880x1620/32"FHDTV/273E3LHSB 27" 1920x1080/6.67"/LTPO AMOLED panel FHD+120hz/7" FHD 120hz
Audio Device(s) Logi Z333/SB Audigy RX/HDMI/HDMI/Dolby Atmos/CVJ NightElf/Moondrop Chu II+BT20S/Nekocake GfL QBZ-191
VR HMD Medion Erazer
what's the point of that question ... if it was difference between Maximus VII Hero and Maximus VII Ranger (both ATX) i would understand but mATX is obviously because : less space availiable, and for a 5.1 you only need 3 jacks, so i can safely assume the Gene can only do 5.1 without jack retasking (thanks erocker)and the Hero(Ranger) can do 7.1
43,629 (6.36/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Hero:
ROG SupremeFX 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- SupremeFX Shielding™ Technology
- ELNA premium audio capacitors
- Blu-ray audio layer Content Protection
- DTS Connect
- Optical S/PDIF out port(s) at back panel
- Sonic SoundStage
- Sonic SenseAmp
- Sonic Studio
- Sonic Radar II
Gene:
ROG SupremeFX Impact II 8-Channel High Definition Audio CODEC *4
Audio Feature :
- DTS Connect
- Sonic SoundStage
- Sonic SenseAmp
- Sonic Studio
- Sonic Radar II
*4: 8-channel audio output is supported by jack-retasking using a chassis with HD audio module in the front panel. <This is the difference
1,503 (0.37/day)
Processor 11900K
Software Win10 Pro
GrieverBlade, I understand its a different layout due to space limitations. So..the difference is mATX is 5.1 unless you use the computer cases headphone jack in the front if the case has an HD audio module to plug into the board? Soo..I think I understand that you need more than 3 jacks for 7.1 and only 3 for 5.1 ... What I'm trying to understand is the difference in the jacks..why have multicolor and then just black? I think color is for the different channels right? What jacks would be used for 5.1 and 7.1 on the ATX boards? Sorry if my questions seem dumb and uneducated..this is just one part of the boards I don't quite understand.
8,570 (1.81/day)
i was half sure of the front jack retasking... thanks @erocker :clap:
both can do 8 channel (7.1) as erocker said the color means no real things between the 2 board: the marking on the I/O Shield are important, the coloring is just a little add.
IE: my Ranger use light brown/black/green but even if my jack and plugs from my Z530 have coloring but i read the Rear/Front(line out)/Sub(CTR/bass) on the Shield.
see that pics for example
5,048 (0.91/day)
València la Vella
Although the Realtek software informs and asks about what you are plugging in, I feel that not using the color code is a screaming lack of love to detail.
And well it has been said, you can use the front panel for more speakers.
One thing that disturbs me personally is: it has autodetection of headphones. But headphones use to be 2 channel. If you have 5.1 of whatever speakers set up, does it switch to stereo with the headphones and back to 5.1 when unplugging them?
1,034 (0.22/day)
New Jersey, USA
System Name Current Rig
Processor AMD 7800X3D
Motherboard MSI x670e Tomahawk wifi
Cooling Artic Freezer II 360
Memory G.Skill 32gb ddr5 6000mhz
Video Card(s) AMD 7900XTX 24 GB
Storage Samsung SSD 980 PRO 2TB
Display(s) Alienware AW3420DW 120 Freesync
Case LianLi Lancool III white non-rgb
Audio Device(s) Onboard ALC
Power Supply Corsair Shift 1000W
Mouse G502 Hero
Keyboard Ducky Shine 5
Software Win 11 64bit
Benchmark Scores The second best!
I run Optical S/PDIF out from the back panel to my 5.1 system. If I need to use headphones, I plug them into the media console. Optical S/PDIF is the easiest and better audio solution if you can swing it.
1,503 (0.37/day)
Processor 11900K
Software Win10 Pro
Really? Optical is better solution? I was under the impression it was the other way around.. Now I'm all confused. I think Erixx cleared up my thoughts about how to get mATX boards 7.1 . "use the front panel for more speakers" I was planning on using headphones only, but now I hear optical is better..decisions decisions..
1,683 (0.32/day)
State College, PA, US
System Name My Surround PC
Processor AMD Ryzen 9 7950X3D
Motherboard ASUS STRIX X670E-F
Cooling Swiftech MCP35X / EK Quantum CPU / Alphacool GPU / XSPC 480mm w/ Corsair Fans
Memory 96GB (2 x 48 GB) G.Skill DDR5-6000 CL30
Video Card(s) MSI NVIDIA GeForce RTX 4090 Suprim X 24GB
Storage WD SN850 2TB, Samsung PM981a 1TB, 4 x 4TB + 1 x 10TB HGST NAS HDD for Windows Storage Spaces
Display(s) 2 x Viotek GFI27QXA 27" 4K 120Hz + LG UH850 4K 60Hz + HMD
Case NZXT Source 530
Audio Device(s) Sony MDR-7506 / Logitech Z-5500 5.1
Power Supply Corsair RM1000x 1 kW
Mouse Patriot Viper V560
VR HMD HP Reverb G2
Software Windows 11 Pro x64
Benchmark Scores Mellanox ConnectX-3 10 Gb/s Fiber Network Card
You both are partially right. If you're transmitting 5.1 over optical S/PDIF, then you have to be using Dolby Digital or DTS, which means you are using lossy compression. The optical output has 0dB of noise, but the tradeoff is that you then get compression artifacts in the audio (especially with DD since it has 60% less bandwidth than DTS).
If you have a high SNR audio codec, you don't have anything near your case that generates lots of EMI, and you aren't using extremely long cables, then analog is probably better than digital optical.
The ultimate solution is HDMI, which transmits multichannel audio both digitally and losslessly.
1,034 (0.22/day)
New Jersey, USA
Mouse G502 Hero
Correct, I should have mentioned I have DD and DTS along with analog inputs that I have tested and have found Optical S/PDIF to be the best solution for me.
Perceived audio quality is sometimes very subjective and other times clear cut when using different outputs - speakers/headphones/etc.
If you can do some audio testing I'm sure you'll hear which provides a better listening experience for you.
