RTX 2060 Random stutters and frametime spikes
thewillox1
12 (0.01/day)
Hi.
About three months, my GPU gave me a black screen for like 10 seconds, while i was playing Multiplayer Modern Warfare (2019) then returned to normal. That happened a couple times, then this weird stutter, frametime spike or my screen freeze for like a half second, happens randomly when im gaming. I did a fresh new Windows Install, trying to fix the issue, but when it was loading, the Windows logo screen seemed kinda weird (it was some kind off scanlines above the Windows logo) and im not sure that it has something to do with the video but im afraid it does. Im always up to date with the lastest drivers.
Anyway, ive been Testing on COD MW (2019), Hellblade, The Withcer 3 and COD BO Cold War at 140 fps locked on Rivatuner, to match the 144hz of my monitor, and VSYNC On inside the game settings with the same results. 1080p Medium settings all games, even with low settings i have the stutter issue.
- MOBO BIOS version is E7B22IMS.2B0
- Windows version is 19041.630.
- I have the lastest Nvidia Drivers 457.30 and did a fresh install using DDU.
- The PSU is Corsair RM750W 2019 version and its 2 months old.
- The refesh rate is 144 Hz 1920 x 1080 in game and also out the game.
- Im using the standar DP Cable that came with the monitor.
Honestly, ive been trying to find a solution in several forums and tried lots of thinga that nothing seems to help. Any help would be very apreciated.
My Specs:
  • CPU i5 8400
  • GPU MSI RTX 2060 Gaming Z
  • Mobo MSI B360 Gaming Plus
  • 2 x 8 gb 2666 Mhz HyperX Fury
  • SSD Samsung EVO 860 500 Gb
  • PSU Corsair RM 750 W 80+ Gold
  • Monitor AOC G2590PX 144hz 1ms
Beside obvious reinstallation of drivers, checking other components, temperatures, frequencies, latencies, i think your GPU might be bad.
This sounds like the stutter i got from having bitdefender installed - what software do you have running while gaming?
You ain't seen n-n-n-n-nothing yet. ;)
Im on the lastest drivers to this day, cpu temp is between 50° - 60° and GPU 68° - 70° while gaming. Any recommendation to corroborate is the bad gpu?
Nope, i dont have Bitdefender installed. I only have the default gaming launchers installed on (Steam, Blizzard, etc) but only open as the game requieres, Discord, Adobe Acrobat DC.
Run Resource Monitor and keep an eye on it whenever there is a stutter. Can use GPUZ to record a log of other things.
Check VRM's next on mobo, etc
I have now installed GPUZ. What should i specifically record to the save sensor log?
How should i check it? Im kinda lost at that. Any advice?
Run a *long* CPU benchmark like cinebench R23, see results. Blow fan over VRM, repeat test.
If your CPU
You can also do this with a room fan and blow a friggin hurricane inside your PC to blindly check if some random component is overheating during gaming, and see if the stutter goes away (but this is a hell of a lot less scientific)
If your CPU
GpuZ logs all sensor listed, record it while running cinebench like @Mussels suggested. Dont forget to note the time when stutters occur during logging, it makes it easier when reviewing the log.
That's a pretty low power CPU, I really doubt the VRMs have anything to do with this.
Safe to assume post the log as requested too hard for ya?
blame @Mussels ! :p
Never had any problems with my MSI Ventus GP 2060 and I run 2560x1440 too. I also don't run the latest driver.. I am on 466.63
blame @Mussels ! :p
its always my fault
and then theres me getting black screens and driver restarts cause my PCI-E power cables were melting, people really give us too little info to solve these things
Change monitor cables and ports, AOC is bad on quality.
blame @Mussels ! :p
Kinda. I can run try running the Cinebench benchmark. But honestly, i already lost every hope i had.
I replaced the DP cable that came with the monitor with a better quality one. https://www.amazon.com/gp/product/B078HVDMW2/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
The monitor only have 1 DP port. I tried swtiching every single DP port on the GPU and nothing changed.
Nope. Never tried that Nvidia Reg Tweak. Is the one on the link you just provide?
I have to mention, im having that issue almost for a year now. At the time i posted, i was using 457.30 drivers.
yes, thats why i linked it
The black screen and the windows logo looking corrupted is a little concerning. If your gpu is failing, you could try using Afterburner to reduce your clocks a bit and see if the stuttering goes away.
My only other suggestion is have you checked if "Message-Signaled Interrupts" is enabled on your GPU? Some people report this helps with latency.
Download "MSI utility v3" from the following page (scroll down to the red text - the download link just above that) :
https://forums.guru3d.com/threads/w...ge-signaled-based-interrupts-msi-tool.378044/
It's recommended you set a restore point before change any settings.
Run the MSI utility v3 as administrator, tick the box next to your gpu, apply, restart and test.
