RTX 2070 SUPER LOW PERFORMANCE
Mactavishftw
4 (0.00/day)
Hi, i recently adquired a new PC with a GALAX RTX 2070 super, and i am having problems with the framerate in warzone, i barely hit 100 fps with everything in low, in multiplayer i can get like 170 fps but in warzone the performance is too low, i tried switching my rams to dual channel, set to 3200mhz, i boost the cpu clock a little bit (cpu clock in 3950 mhz) but still get low framerate, i update the bios but nothing seem to work, i play on a 144hz monitor so im concerned about this issue, i hope you guys can help me, i will mention my pc specs below, thanks.
CPU: Ryzen 5 3500x 3.6ghz AM4
MB: Asrock B450M PRO4-F
RAM: Thermaltake Toughram Z-one DDR4 16GB (2X8) 3600MHZ
GPU: GALAX Geforce 2070 Super 8gb
PSU: CORSAIR CX650 650W BRONZE
Monitor: LG LED 24GL600F-B 144hz 1080p
SSD: Solid Western Digital 1TB
can you set your windows power settings to 'maximum performance' and see if that does anything for you? Also set your 2070 to "prefer maximum performance in the control panel"
I have already done that, i play Amd ryzen high performance power plan and set maximum performance on the nvidia control panel but still get around 100 fps, i have seen benchmarks in youtube with the same gpu runing at 180 fps with no problem in low settings, so i dont know what would be the problem
Run some monitoring apps to see if your clocks are dropping on CPU/GPU
Warzone is an absolute cluster fuck of optimization. Though I suspect if you had a 1440p screen it would be better still, or more in line with what it should be.
What is your GPU utilization. Not just CPU?
How does it run on other games?
EDIT: 77% GPU usage....
Have you tried a driver re-install using DDU to clean out the previous driver install?
Recommended specs 4c/4t Intel and...6c/12t AMD Ryzen 5 1600x. Eventually 8c/16t AMD when gaming on competentive and ultra.
Low gpu usage and high CPU usage -- cpu bottleneck at the time of screenshot as @P4-630 mentioned.
What do you have running / open in the background?
So is bottleneck damn
Yes, i already done that, other games run fine, between 100-130, i dont care about that i just wanna play warzone at high frames, thats why i bought a 144hz monitor, but i messed up on the cpu i guess cuz even on low settings its terrible, i guess im gonna have to sell this cpu and buy a better one, what cpu would be fine to maximize the performance of my current gpu, or at least playing warzone at 144 fps?
I dont have anything in the background, just discord, thanks guys for the answers btw :D
super low performance lol NO ?
cod is cpu bound you are getting exactly the performance one would expect with that hardware
faster ram + faster cpu with a healthy overclock will help but warzone just hits a wall at 100fps it takes a 1090k & 2080 to push it much over 120fps at 1440p
