- Mar 23, 2009
- 45 (0.01/day)
System Name | i7 10700k + RTX 4080 |
Processor | Intel Core i7 10700k @5GHz |
Motherboard | MSI MPG Z490 Gaming Plus |
Cooling | NZXT Kraken X63 |
Memory | 32gb Corsair Vengeance |
Video Card(s) | Palit RTX 4080 Gamerock 16GB |
Storage | 2x500GB M.2 NVME Raid 0, Samsung SSD 840 EVO 500GB, 2x 8TB Seagate Baracuda Compute, ASUS BW16D1HT |
Display(s) | Philips 4k 65' HDR TV |
Case | Raijintek Zofos Evo RGB |
Audio Device(s) | Denon AVR 2400H |
Power Supply | MSI MPG A1000G PCIE5 1000W |
Mouse | Logitech MX Master 3 |
Keyboard | Logitech K350 |
VR HMD | Meta Quest 2 |
Software | Windows 11 PRO |
HI everyone. I have a problem in less demanding game which is Diablo III. On max boost clocks which is about 2050MHz game i smooth as silk (Game is very poorly optimised, only about 60-65 fps on 2050 clocks even that game uses only 40% of gpu power). The problem is that this game use about max 50% of power limit on max settings causing GPU to downclock to 1500-1600MHz. This downclocking cause massive lags in game and massive fps drops. Is there any way to keep boost clocks high even if power limit used is low?
Card is overclocked using curve. Playing in 4K maxed out.
CPU and GPU is cooled by X41 kraken (one for each). Temps are CPU 60deg C max, GPU 41deg C max. So there is no problem here. Screenshot attached.
