RTX 3050 with GA107 GPU incomplete information and sensor issue.
BlackSln
3 (0.07/day)
Die size and transistor count information is not displayed.
In the Sensors tab there is a sensor PWR_SRC Power Draw, which always shows 44.5W, regardless of the load. So the Board Power Draw sensor shows an overestimated value, the 3050 can't have 46.5W consumption at idle. There is also the PWR_SRC Voltage sensor, which always shows 11.1V, which also does not change and is not correct. As I understood, these sensors belong to laptops and should not be on a desktop graphics card. In Windows 10 it is the same. The graphics card is made by KFA2, if that makes a difference.
... are you using Windows XP?
It looks like a skinned Windows 7
Normal, have GA107-based "3050 Laptop GPU" (the original 4 GB, 128-bit model) on my laptop and it has always stated "Unknown" for those, I think TPU's database does not have that information
