novice2009
- Jun 2, 2024
- 12 (0.04/day)
Hi!
I'm amateur and repair graphic cards for fun. Now I have RTX 3070 from Gigabyte with artifacts. MATS had shown faulty A0, A1, B0, C0 memory chips. I replaced all of them but number of errors and faulty channels are pretty the same (with minor difference in number of errors). Before soldering new chips I checked data lines in B0 channel and found all of them good (0.3V opening voltage). Just for any case I heated up the GPU up to melting balls to restore possible bad contacts but result is the same - bad channels A0,A1,B0,C0. Does it makes sense to remove GPU, reball it and put back? Or might be there is another culprit of this malfunction?
Thank you in advance for the reply
