Running 5600mhz DDR5 at 6000mhz?
289 (0.31/day)
Processor Ryzen 5 7600X
Motherboard Asus Proart B650
Cooling Noctua U12S
Memory Corsair Vengeance DDR5 32GB (2x16GB) 5600MHz C36 AMD Expo
Video Card(s) Sapphire RX 7800 XT Nitro+
Storage Samsung 990 Pro 1Tb
Case Fractal Design Pop Silent
Audio Device(s) Edifier r1900tII
Power Supply Seasonic Prime Platinum 650W
Is it generally safe to do? I have 5600 cl36 and when I set it to 6000mhz in BIOS, I didn't encounter any issues.
Perhaps I don't know something, so wondering, is it worth it? Am I reducing RAM longevity or maybe risking overheating or stability issues or anything like that?
System as in system specs here.
It's not a major jump, so its entirely possible.
How did you change the settings and what is your system specs? Can't see on the phone.
I set it to Expo II in BIOS and then simply selected where it said 5600mhz and set it to 6000mhz.
My system is ryzen 7600x on a b650 proart board from asus.
2x16gb ram sticks from corsair vengence.
Running cinebench now with 6000mhz. So far flawlessly stable. Preliminarily i see the upcoming result is above the previous one so there may be a tiny performance increase. As expected i guess.
The benefit appears to be insignificant. Atleast in cinebench r23.
14876 points for 6000mhz
14859 points for 5600mhz
Less than 1% - basically within natural point fluctuation.
You won't see a big increase for R23.
Download and run memtest5 for a stability check. Im not concerned about damaging anything, because you didn't change the DRAM voltage.
Does everything look good please?
