- Oct 9, 2007
- 47,900 (7.37/day)
- Dublin, Ireland
System Name | RBMK-1000 |
Memory | 2x 16GB DDR4-3200 |
Storage | Samsung 990 1TB |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
A lot has been said about AMD's rather mysterious new performance GPU, the RV790. Clues about the new GPU surfaced as early as in November last year, when we first reported about AMD working on a successor to the RV770 before the RV870 comes to be. During the course of time, we were given several scoops about its specifications, with some reports hinting at increased stream processor and TMU counts alongside increased clock-speeds to give out early projections of as much as 20% performance increments, taking its single-GPU flagship product to the domain of the GeForce GTX 285, but as multiple sources confirm now, none of that looks plausible.
The RV790 is essentially a reworked RV770 with higher clock-speeds. AMD seems to have reworked the design of the RV770, perhaps altered or removed rudimentary components that facilitate slightly higher clock speeds. While samples of the RV790 are spec'd to run at 850 MHz, one can expect a slightly increased overclocking headroom. The samples also carried Qimonda IDGV1G-05A1F1C-40X memory chips that are originally specified to run at 1 GHz, yet running at 975 MHz on the samples. The core continues to have 800 stream processors, 40 TMUs and 16 ROPs. It features a 256-bit wide memory interface to support GDDR5, GDDR4 and GDDR3 memory standards. It will be built on the existing 55 nm TSMC manufacturing node. Products based on the RV790 can be expected only by April.
