- May 25, 2013
- 739 (0.17/day)
- Kolkata, India
System Name | barely hangin on... |
Processor | Intel I5 4670K @stock |
Motherboard | Asus H81m-cs (nothing else available now) |
Cooling | CM Hyper 212X (in push-pull) |
Memory | 16GB Corsair Vengeance Dual Channel 1866MHz |
Video Card(s) | Asus RX 580 4GB Dual |
Storage | WD Blue 1TB, WD Black 2TB, Samsung 850 Evo 250GB |
Display(s) | Acer KG241QP 144Hz |
Case | Cooler Master CM 690 III (Transparent side panel) - illuminated with NZXT HUE RGB |
Audio Device(s) | FiiO E10K>Boom 3D>ATH M50/Samson SR850/HD599SE |
Power Supply | Corsair RM 850 |
Mouse | Redragon M901 PERDITION 16400 DPI Laser Gaming Mouse |
Keyboard | HyperX Alloy FPS Mechanical Gaming Keyboard (Cherry MX Brown) |
Software | 7-64bit MBR, 10-64bit UEFI (Not Multi-boot), VBox guests... |
Asus Rx 580 Dual 4GB on a Asus ROG M6 Hero. Fitted on the first 16x slot and everything on UEFI and OS has been properly configured, with no power savings on the PCI-e. At idle GPU-Z shows bus interface 16x gen 3 running at 2x v 1.1. On load that does change to gen 3..0 but the 2x doesn't change. See the screenshots - one @ idle and the other @ load.
