Rx 580 driver timeout error
ThejanaPatthiss
3 (0.01/day)
Why does my Rx 580 2048sp driver crash midway and restarts my pc (while playing GTA V).Is the vbios right .Updating the vga driver doesnt even work.then it would never work as a driver giving a error code :43
Hello.
I encountered the same error on some ASUS RX580 cards.
In my case i discovered that it was a hardware fault.
ASUS had a flaw in card design, so some memory chips were not covered by the GPU shield.
As a result those chips were overheating and in the end they resigned and went to a well deserved vacation in Hawaii.
I mean it.
I am confident that you should seek a professional help from some hardware repair shop.
It is not regarding to the soft rather the hardware part.
This is an asus rx580 card, which is known to have vram cooling issues. Your gpuz screenshot looks fine so i guess its vram problem. Try downclockng the vram to 1500mhz and the gpu core to 1100 with afterburner and see if it still crashes
Good ideea.
At least you eliminate one cause.
i mean
usually it shows that it doesnt go above 65 when gaming.Anyways ill try it .more help is always appreciated
