RX480? Need Help Determining!!
Lapanjo
11 (0.01/day)
Bought it from Taobao, it was so called XFX RX580 8GB. I know it was too good to be true took it about for cleaning and google what i find in the card but can't seem to find bios. GPU chip was labeled AMD 215-087618(RX480?) and the memories are SK Hynix H5GQ8H24MJR (8gb?). i can't seem to find any bios with this combination. please help..
Thank you Caring1
I think i should i made it clear.. is it possible to get the original bios or anything close to the xfx RX480 8gb hynix?
What is the performance different between rx 480 and rx 580 bios?
I have the rx580 bios. i ran The Forest for about 1 hr and i get a black screen and my PC will Shut off. Running Warzone FPS is all over the place, jump between 90 fps down to 15 fps or lower.
i am new to gpu bios but I notice in the gpu data base there are some RX480 with the same chip number. does the bios affect on gpu performance?
i have that same card and the stock bioses caused nothing but pain. i use this bios with the latest amd drivers and the card runs flawless.
also, set the power slider to +50, that will let the card breath nicely.
I ran the Sapphire RX 580 VBIOS, didnt work for me.. when i ran Warzone it crashed...
this should be the right bios for that card..
btw, what is you power supply?
If the gpu have "poloris 10" chip and u flash "poloris 20".. will that affect the performance of the gpu?
If you mean, RX 400 to RX 500, then yeah.
This is the original BIOS for XFX RX 580 GTS XXX 8GB
https://www.techpowerup.com/vgabios/211624/211624
This card is known to overheat in some games.
Download MSI Afterburner and setup a custom fan curve.
This Bios have put my PC now in Black Screen No Dispay. Is there any Polaris 10(215-087618 ) with 8gb Hynix (H5GQ8H24MJR) bios.. now i dont care if its 580, 480 or whatever as long as i can get this card going till i can buy a new card ..
XFX RX 580 8GB Hynix
XFX RX 480 8GB Hynix
