RX480 thread stuck in device driver
Frannava2018
4 (0.00/day)
Hello, these day I was trying to fix a rx480 but i have a problem, when I put the Adredalin for put the drivers, my sistems fail and i have a thread stuck in device driver problem. I tried again, but cleaning the drivers with DDU and flashing a new bios version, but I have the same problem. My theory is I have a hardware problem. Can anyone help me sending a post that have the issues? Thanks.
1,891 (1.29/day)
Romania
System Name Gaming1 / Office 2
Processor Intel i7 7700k@4.8ghz / Ryzen 7 5700G
Motherboard MSI 270 SLI PLUS / MSI MAG X570S - TOMAHAWK MAX WIFI
Cooling ID-Cooling Frostflow X 120 - Liquid / ID-Cooling SE-903 V2
Memory 2x16GB Corsair Vengeance LPX 3600 Black / 2x16GB Corsair Vengeance RGB Pro SL - 3600Mhz
Video Card(s) XFX RX 6600XT 8GB / XFX RX 5700XT THICC III Ultra 8GB
Storage 1st : 1x SSD Samsung 980 Pro 1Tb + 4x SAS HDD in RAID / 2nd : 1 Tb SSD Nvme Samsung 980 Pro 1Tb
Display(s) 2x Dell 3008 WFP
Case CoolerMaster HAF 932 / GENESIS IRID 300
Audio Device(s) Soundblaster XFI / Onboard
Power Supply Seasonic Focus 850 W / Seasonic Focus 850 W
Mouse Logitech G502 HERO / Logitech G5
Keyboard Dell SmartCard Reader SK 3205 / Dell SmartCard Reader SK 3205
Software 1st - Win 10 Pro X64 / Win 7 X86 / Ubuntu / 2nd - Windows 11 Pro x64
Ok. Try to do the following in this order :
- restart in safe mode
- use DDU to uninstall drivers
- flash the BIOS that came with the video card (original one)
- install drivers
- use atikmdag patch for pixel
- restart computer and run a test to check for errors
Frannava2018
4 (0.00/day)
- install drivers
One question, If I cannot enter win with the GPU , because I'm in a loop with the same error (THREAD_STUCK_IN_DEVICE_DRIVER), is it ok if a use another GPU? For example, a IGPU?
Edit: I forgot to mention, I don't have video in the rx480 so i'm using a ryzen 3400g.
1,891 (1.29/day)
Romania
ok - can you take off the video card ? i mean rx480?
Try to boot with a discrete video card (onboard and uninstall drivers)
In case you do not have onboard video try to use another video card (no matter how old it is) in order to uninstall drivers from system
unplug from internet (in order to avoid system to update video drivers from web)
Then put back rx480 into system and continue with flashing the original BIOS ....
keep us informed
Frannava2018
4 (0.00/day)
Ok, now I'm going to try. Thank and I will write again to say what happen.
keep us informed
Now I'm with the phone. I do the process and windows cannot start if I put the video with the Ryzen 3400g, the fans of rx480 stop. Also, I tried to use the rx480 but the PC stuck in VGA check.
1,891 (1.29/day)
Romania
OK so let me understand.
You took out the rx480, you uninstalled the drivers?
Then you take off internet?
Then you put back rx480 ?
And when you start computer you did set up as the main video card the card onboard ?
Frannava2018
4 (0.00/day)
Yes, I unistalled all the drivers and the software
Yes, I unplugged the ethernet
Yes, and I did this :
- install drivers
- restart and win cannot bot if I put as a main video card the card on board. Then, I tried to put as a main video card the rx480 and the PC stuck in VGA chech.
Yes, I set up as a main video before I restart in safe mode
1,891 (1.29/day)
Romania
Pfffff
I am very sorry mate.
So let's roll back a little.
All were good few days ago?
Then you changed the video driver only ?
Or you also flashed the BIOS at the next step ?
I suspect that you cause some hardware level damage due to the newly flashed BIOS, possibly cause they used more aggressive the memory that can cause memory chips failure.
1,909 (0.32/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
If it's not booting the flash isn't working or taking.
44,283 (6.80/day)
Reinstall your OS or use the Radeon Enterprise driver
