A new bios editor has bin released: https://www.igorslab.de/en/now-also...ly-with-full-support-for-the-older-amd-cards/
I've editted my current bios with it (It holds a 250W TDP) to increase the maximum core voltage that was allowed. I can push 1.3V now in Wattman if desired, where before i was just limited to 1.15v or so. There's another option in there, to increase the memory voltage, and not controller, which i did from 1.1V to 1.2V. Since ive loaded up the 1600Mhz straps onto the 2000Mhz profile, i could bump the clocks now up to around 2140Mhz which is a 100Mhz increase. I see good gains, because if i compare this bench:
With my own, at 72.5 using Ultra quality preset, then i've done a good job so far. I am able to push the core to 1500Mhz, and having it watercooled using a AIO with 2 fans. Max temp? Around 60 degrees. Ive attempted to run furmark, not knowing the extreme preset was turned on, so it kind of peaked to 300W GPU power consumption, my UPS triggering and 22A on the 12V line being consumed, lol.
I think going beyond 1500Mhz from this point is dull; the power consumption and heat will only go up with barely no improvement. How much is this memory (Sapphire RX580 8GB) capable of really? If i am able to push a few more mhz out of it then i might be happy for a good overclock, since the RX580 is pretty much bandwidth starved. More = better.
