- Oct 4, 2023
- 10 (0.02/day)
Processor | Ryzen 5 7500f |
Motherboard | B650 GAMING PLUS WIFI |
Cooling | Arctic liquid freezer II 280 |
Memory | Lexar ares 2x 16gb, 6000MHz CL30 (30:36:36:76; probably stable) ;uclk=memclk |
Video Card(s) | Pny rtx 4070 verto xlr8 12gb gddr6x |
Storage | Lexar NM710 2TB M.2 |
Display(s) | LG ultragear 27gp850p |
Case | Be quiet pure base 500 |
Audio Device(s) | Sound blaster z se |
Power Supply | Be quiet! straight power 11 750 W |
Mouse | Steelseries prime |
Software | Windows 11 |
Hello,
i have a new pc and from last 2 weeks i try to configure it with UV for gpu, cpu, setting fans etc., I haven't had a pc for almost 8 years, so everything is new to me and I have to learn everything from scratch.
I read a lot about undervolting with ryzen master and Curve Optimizer, but it seems its completely not working on my system, to put it simply, it sets the values that I set as maximum, if I set the maximum offset to 30 it gives -30 to all cores, if I set it to 33 it gives -33, and interestingly it sets the first core either to -50 or -255.
During tests in cinebench, 3dmark, mem64, my system reset at random times, I thought it was the memory's fault, I tested them using mem64 on various settings, but there was always a reset at some point.
I finally figured out that it might be a cpu issue, and in fact, after turning off the UV, the resets stopped.
Has anyone had a similar experience? maybe some hint as to why cu doesn't work at all for me?
I have all the default settings in Ryzen Master, when it starts I go to basic mode, run Curve Optimizer, and then in advanced mode I check what values it has set.
