Hey guys,
so I just bought an RX 570 4GB that I wanted to clean up and give it to my father as an upgrade for his PC. However, when I was testing out the graphics card, I was unable to install the GPU drivers. I tried both manually selecting it on the AMD website as well as the one with automatic detection. The manual one would not even install. The automatic one does but I get an error msg. The error msg points me to an AMD FAQ that lets me download an "amdsoftwarecompatibilitytool" which tells me that everything is as it should be.
I noticed it has a BIOS switch on the PCB which I tried out but got the same result. The only difference was lower GPU clock and higher frequency.
I also tried using the Display Driver Uninstaller but that did not fix my problems.
When I talked to the guy that sold me the GPU, he told me that he has no idea whats going on and that he is using another GPU just like this one in his personal PC. He had 4 and all were used for mining prior to that.
What am I missing here? What could be wrong with the GPU and how could it be fixed?
Thank you.
Thank you.
