Sapphire Pulse RX5700 BE problem flash bios
VtnXr22
12 (0.02/day)
Hello, I have a problem with uploading the BIOS to the cards after entering amdvbflash - and the test fails and I cannot upload the BIOS, only the amdvbflash version is 3.04+, I provide the information and the test runs successfully, but an error appears when I try to flash the cards. I've heard of a method to short-circuit pins 1-8 in the BIOS chip, but but I don't know if I can do it. Please help. The card works normally. If I made any mistake in writing, I'm sorry, my English is not very good
Hello.
Please make more tests with the card.
If all the tests will pass then you have a fully functional card.
Remember that at the end of a flashing procedure, the program makes a CRC check.
It is more likely that the CRC failed cause some bit was not written corectly.
the card works well under load, does not turn off and so on
Is there any way to fix this?
Can someone send me the original bios for this card?
Would you be so kind and make some pictures (we already have the label) :
- GPU-z - main screen
- GPU-z > Adavanced Tab > and choose memory info
this what you mean?
Unfortunately, the XT bios card gives a black screen when FurMark is temporarily loaded, so I will ask for a bios for the regular version. The bios was successfully flashed on Linux
Hello.
I searched BIOS-es that matches your card's spec.
You posted GPU-z main screen and there you have XT version written .
So i presumed that you have XT.
I sent a photo and it says rx 5700 be and not xt and this gpu photo is just the bios flashed to xt which I managed to flash
The pic you posted at post #6 def says 5700XT.
We are glad that you've made it.
Cheers!
