PC Specs:
CPU: Ryzen 3 3200g 3.6ghz
Motherboard: Asrock x370m-hdv R4.0
Ram: Patriot Viper 2x8gb DDR4 3200mhz
PSU: Thermaltake TR2 600W
A few weeks ago I got a Sapphire Pulse RX 580GB 8GB (used for 6 months).Ran the AMD Cleanup Utility and installed latest drivers, then I put it to work playing RDR2 at 1080p with low settings and the display would start to glitch and show artifacts and eventually crash into a solid color screen, PC and peripherals stay on but no sound. Restarting the pc would fix the crash. This only happens when playing heavy games, particularly in full screen and 1080p, if I lower the resolution to 720p is not as frequent. Also when idling or doing light tasks it doesn't crash.
Tried installing old drivers but it would just make it worse. Also tried updating the motherboard BIOS but didn't help.
I searched online and found many people having similar issues and apparently they are fixed flashing the GPU BIOS, but when I could not find the correct BIOS file for my gpu.
Also, this is what GPU-Z shows:
I would greatly appreciate if someone can help me find the correct bios file or have any other solution to this problem. Thank you very much!
