Screen flickers/shows pixels at will! What's wrong and how to fix it?
651 (0.11/day)
Norway, which means Amazon is not available...
System Name Winter v3.2024
Processor Intel i7 12700K (since november 2021)
Motherboard Gigabyte Z690 Gaming X (since november 2021)
Cooling Air Liquid Freezer II 360 with LGA1700 kit (since november 2021)
Memory Crucial Ballistix 2x16gb 3600mhz C16 (since november 2021)
Video Card(s) Gigabyte RTX 3060 Ti Gaming OC Pro LHR - Rev3.0 (since july 2022)
Storage 1x 1TB WD Blue SN570 SSD, 1x Seagate 4TB SATA
Display(s) 1x 55" LG C1 4k OLED, 1x Gigabyte 32" M32Q and 2x AOC 27" CG1
Case Fractal Design Define R6 (since 2018 and still working like a charm!)
Power Supply Corsair RM850x black (since august 2022)
Mouse Razor Deathadder v2 (since december 2021)
Keyboard Varmilo VEA109 v2 MX Silent Red (since august 2022)
*topic*
Every now and then when i am watching youtube, the screen decides to suddenly display random pixels here and there. Reminds me of some kinda flickering...
Here's a video on what i am on about: https://streamable.com/uym1vn
How do i fix this issue?
See my specs list. I am using Windows 11. Newest drivers for gpu as well.
Looks like artifacts caused by the video card.
I think I've heard about this problem before (and experienced it, to a lesser degree). If its what I'm thinking it is, its pretty common. Try disabling hardware acceleration in your browser (or enabling it, if its disabled). I think there's a better way to fix it but I can't recall at the moment. It might have had something to do with refresh rates. Whats yours?
Check this out:
This MIGHT be the bug thats been present in Chrome for like half a year now and still isn’t fixed that borked how HW acceleration works with the browser. Rather than, as advised above, completely turning it off (which while potentially helpful will lose you quite a bit of performance), you might want to try chrome://flags/#use-angle and changing ANGLE graphics backend to OpenGL. This helps in majority of cases seemingly.
Thats exactly what I had edited into my post several minutes ago, lol.
But is this happening on amd cards? Because, if its happening in other applications too... Making me think perhaps nvidia has a role to play in fixing this.
Check this out:
Mothaland! Wow, that actually fixed it! I watched a 2-hour docu on YT and not ONCE did it occur!
The method you two mentioned also works in Brave, by the way! :)
ONCE again, TPU to the rescue! Kudos for that. Happy holidays!
It is a predominantly NV issue, yes. No idea what or why has broke and who actually needs to implement a fix between NV and Chromium though. Since it’s been going on for a while now it seems no one wants to admit to a fault.
do you have any issues playing modern titles? if not it could be a software issues clashing with drivers...
few factors contributing... windows 11, drivers and the software you are using...
Thanks for that note. I will keep that in mind, yes. But so far, the solution provided above seems to be working brilliantly for now. :)
