Screen Rez Probs
491 (0.07/day)
A small crate floating in the Pacific..
Processor Athlon64 X2 3800+ @ 2.6Ghz
Motherboard BioStar TForce4 SLI (939)
Cooling Stock Opteron Heatpipe Cooler
Memory 4x512 Crucial BalistiX, @ DDR520, 2.5-3-3-8
Video Card(s) ATI, x1900 AIW (600/620)
Storage 80GB SATA2, 320GB eSATA2
Display(s) AGM 19" Widescreen LCD, 4ms
Case Aspire X-Dreamer (Black)
Audio Device(s) Auzentech: X-Meridan (Best Soundcard Ever)
Power Supply Rosewill 550W 2x12V
Software XP Professional X64 & Ubuntu 7.10 x86
Hey, I've run into a bit of a prob getting windows to display at my desired rez. I'm using a 19" Widescreen on Vista Beta 2 (64-Bit), and I want to use 1440x900.
It worked before I installed my ATi drivers.. now I only get the non-widescreen options.
driver bug. just lookup mods for them elsewhere. You ARE on beta software...
isnt there options to set custom res's in the CCC?
edit: i mean mods for adding custom resolutions, they're all over the web.
i like useing the 1400 x 900 resolution even thow i have a 20 inch monitor..
the ati/windows drivers gave/give me the option with an x850/800 card but not with a 1900 card.. why i should get different options with two different cards i have no idea..
i havnt found it that easy to get it back.. i am useing normal xp..
trog
