Screen won't auto or manual adjust, borders aren't filling
1,555 (0.25/day)
Shepparton, Victoria, Australia
System Name Toaster!
Processor Intel Core i7 10700KF @ 3.8/5.1GHZ
Motherboard ASUS Prime Z490-P Motherboard
Cooling Noctua NH-D15 CPU cooler.
Memory G.Skill Trident Z RGB 64GB (4x16GB) 3600MHz CL16 DDR4
Video Card(s) ASUS ROG Strix GeForce RTX 3090 OC 24GB
Storage Samsung 970 PRO M.2 NVMe SSD 1TB
Display(s) Asus ROG PG43UQ 4K UHD 144Hz G-Sync HDR 43in + 2 x ASUS VG258Q FHD 144Hz Freesync 25in Monitor
Case Corsair Obsidian 900D
Audio Device(s) EPOS Sennheiser GSX 1000 V2 amplifier + EPOS Gaming GSP 601 Headset
Power Supply Corsair AX1000 Titanium Modular
Mouse Razer Deathadder
Keyboard Corsair K70.
Software ALL HAIL WINDOWS 10.
Benchmark Scores Old system: http://www.3dmark.com/fs/6805248
Ok I recently got my brand new Viewsonic VX2753MH 27 inch 1ms LED LCD Monitor.
But the screen isn't adjusted. And won't allow auto/manual adjusting. The overscan has to be set @ 10 percent for it to fill the borders, but even then the picture is still blurry
It's on a DVI to HMDI adapter and my 7970 only has the 1 HDMI slot and 2 MiniDP slots + DVI slot, I tried a MiniDP to HMDI adapter but that didn't work also. The driver is installed also.
look under my digital flat panel /scaling options
edit: maybe a defective card?
Fixed it guys.
For some stupid reason you have to go to the monitor settings using the buttons on the side then go
> Input settings
Then select the appropriate input, only then will it fill the borders without needing overscan.
The picture is clear now. Poor screen design.
Meh, Viewsonic. My first LCD display (10 years ago-ish?) was a Viewsonic and had this same issue... Not to mention others.
