- Jun 5, 2007
- 2,167 (0.33/day)
- Metro Manila, Philippines
System Name | Zangief (Reborn) 2.0 AM4 not dead yet! |
Processor | AMD Ryzen R7 5700X3D (tweaked PBO) |
Motherboard | Gigabyte GA-AX370 Gaming K7 Rev 1.0 BIOS F53d |
Cooling | Noctua NH-D15 Push / Push Config | 2x ML120 | 2x Phanteks 120 mm |
Memory | 2x16GB G.Skill Trident Z Neo RGB @ 3600mhz CL 18 -> running 3800mhz @ 1.37v |
Video Card(s) | Asus RTX 3080 Rog Strix Gaming OC |
Storage | 250 GB Samsung Evo 850 / 1tb WD Black / 4tb WD Blue / 512GB Adata XPG Pro SX8200 |
Display(s) | Acer Predator XB271HU |Asus VX239H 23" AH-IPS Led |
Case | Phanteks Enthoo Pro M TG |
Audio Device(s) | On Board Realtek HD | Steelseries Arctis Nova Pro Wireless |
Power Supply | Seasonic Focus GX V4 850 Watts ATX 3.1 |
Mouse | Logitech G903 |
Keyboard | AKKO 5098N (Otemu Cocoa Brown Lubed) | Tecware Spectre 96 (Akko Lavander Purple V3 lubed) |
Software | Windows 11 Pro 24H2 |
Specifically for pausing desktop slideshow.
Can anyone guide or help me set up a If -- Else script for toggling pause and available options for current power scheme.
Basically change Power Options > Advanced power settings > Desktop Settings > Slide show.
I can do it via cmd/powershell with powercfg but not really good with making a complex script.
like a 1 click on and off script that can read the value or something like that.
The command which can do this is.
powercfg -setacvalueindex or powercfg -setdcvalueindex plus the GUID of the setting.
Thank you.
Thank you.
