Scythe Introduces Slim Stream 120 PWM High-RPM Fan
47,658 (7.43/day)
Japanese Cooling expert Scythe is announcing the availability of a new High RPM version of the popular Slip Stream PWM fan series. Slip Stream 120 PWM High-RPM is equipped with PWM feature which allows the mainboard to automatically control the fan speed in a range between 500 (+200 rpm) and 1,900 rpm (±10%) whereas the airflow of up to 110.31 CFM is being created which equals ca. 187,41 m³/h. This allows the High RPM version to cover a wider range compared to the already existing Slip Stream 120 PWM fan which is spinning in a range of 0 (+200 rpm) and 1,300 rpm (±10%) making the High RPM version suitable for high performance systems as well as overclocking use.
Besides the Slip Stream 120 PWM Adjustable which allows to adjustment of the PWM bandwidth and the Slip Stream 120 PWM & V.R. which additionally gives the possibility to manually control the fan speed using the Voltage Regulation, new Slip Stream 120 PWM High-RPM is equipped with the standard PWM feature allowing the automatic fan control via the mainboard.
New Slip Stream 120 PWM High-RPM is available for 7,25 EUR (excl. VAT) or 12.00 USD.
Product Details
Model Name: Slip Stream 120 PWM High-RPM
Model No.: SY1225SL12LH-P
Fan Dimensions: 120 x 120 x 25 mm / 4.72 x 4.72 x 0.98 in
Fan Speed: 500 (+200) - 1,900 rpm (±10%)
Noise Level: 7.5 - 37.0 dBA
Air Flow: 24.50 - 110.31 CFM = 187.41 m³/h
Weight: 121 g / 4.27 oz.
Connector: 3-Pin (4-Pin Molex Adapter included)
Bearing Type: Sleeve Bearing
Current: 0.51 A
Operating Voltage: 12 V
MTBF: 30,000 Hours
For more details, visit the product page.
OneMoar
There is Always Moar
8,837 (1.61/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
meh
bought 2 of these both move quiet alot of air AND emitted a electrical-melting smell and gotten very very very warm + they are very LOUD 40DBA+ in my case I have since RMAed them and gotten 2 cheap rose wills instead
my verdict: AVOID electrical smells are always BAD :shadedshu
628 (0.10/day)
Finland (northern)
System Name Getting old!
Processor AMD Phenom II X4 965 @ 3,9Ghz
Motherboard Gigabyte GA-MA790GP-UD4H
Cooling About sufficient air cooling
Memory 4GB Dominator DDR2 1066 @1040Mhz
Video Card(s) Club 3D Radeon HD6950 1GB
Storage 120GB Kingston SSDNow 200V+, 1TB Samsung Spinpoint F3
Display(s) Crossover 27Q LED-P (lovely!)
Case Antec Three Hundred
Audio Device(s) Integrated -> optical -> HELIX P DSP
Power Supply Corsair HX620W
Software Win7 64-bit
Benchmark Scores 3DMark11 P5285 WPrime 1.55 10,15 sec Super Pi Mod 1.5 17,920 sec
I have three non-PWM versions of these and they have absolutely the best noise to CFM ratio I have ever encountered. I've read some few posts about bearing quality being bad and overheating problems. But I've had zero problems with these and I would definitely buy these again. Though, I don't use them at full 12V because there is no need. :) A PWM version would maybe be better for CPU use. But my mobo controls the CPU fan speed beatifully.
EDIT: Plus the cost is reaaally low compared to the quality of these things.
OneMoar
8,837 (1.61/day)
Rochester area
that its probly why you are not haveing issues you are not useing them at 12
les power = less stress on the coils = les chance of meltdown
5,393 (0.92/day)
Kingsville, TX
System Name ODIN
Processor AMD Ryzen 7 5800X
Motherboard Gigabyte B550 Aorus Elite AX V2
Cooling Dark Rock 4
Memory G Skill RipjawsV F4 3600 Mhz C16
Video Card(s) MSI GeForce RTX 3080 Ventus 3X OC LHR
Storage Crucial 2 TB M.2 SSD :: WD Blue M.2 1TB SSD :: 1 TB WD Black VelociRaptor
Case Fractal Meshify C
Audio Device(s) Onboard Audio
Mouse Corsair M65
Keyboard Corsair K70 RGB Lux
I have one of the originals as it came with my Scythe Mugen 2 CPU cooler. Just like in this picture, they are 4 pin, not 3 and the original is virtually silent as my case fans are much louder. It moves enough air, but I think I will get one of these for a 500 RPM boost. Or I could by the extra bracket arm and do a push/pull with the CPU cooler.
WarEagleAU
Bird of Prey
10,812 (1.57/day)
Gurley, AL
System Name Pandemic 2020
Processor AMD Ryzen 5 "Gen 2" 2600X
Motherboard AsRock X470 Killer Promontory
Cooling CoolerMaster 240 RGB Master Cooler (Newegg Eggxpert)
Memory 32 GB Geil EVO Portenza DDR4 3200 MHz
Video Card(s) ASUS Radeon RX 580 DirectX 12 DUAL-RX580-O8G 8GB 256-Bit GDDR5 HDCP Ready CrossFireX Support Video C
Storage WD 250 M.2, Corsair P500 M.2, OCZ Trion 500, WD Black 1TB, Assorted others.
Display(s) ASUS MG24UQ Gaming Monitor - 23.6" 4K UHD (3840x2160) , IPS, Adaptive Sync, DisplayWidget
Case Fractal Define R6 C
Audio Device(s) Realtek 5.1 Onboard
Power Supply Corsair RMX 850 Platinum PSU (Newegg Eggxpert)
Mouse Razer Death Adder
Keyboard Corsair K95 Mechanical & Corsair K65 Wired, Wireless, Bluetooth)
I love the slipstream and especially the one they included with the Mugen 2, it is pretty silent and moves a good amount of air. I am thinking of getting another for the Mugen 2 to have a push pull config.
