Seagate external hard drive not powering on
Lemwolf
8 (0.00/day)
I have a Seagate external hard drive 1500 Gbytes and it used to be in a case. The other day I noticed the power button wouldn't come on, even after switching cables etc. So I removed it from the case and tried to hook it up to my computer. After I hooked it up I noticed my computer wouldn't turn on. So I removed the drive and my computer came back on. So I tried another computer same thing. Ok so today tried it with a docking station and again while the harddrive is connected the power will not come on but as soon as I take it out the power on the dock returns. What could be the issue?
dorsetknob
9,106 (1.24/day)
Dead Drive !!
you can Verify the Enclosure is ok by testing with a known good replacement Drive ( size does not matter ).
Lemwolf
8 (0.00/day)
Now when u say dead drive. Is it this piece that needs to be replaced?
dorsetknob
9,106 (1.24/day)
No i suggested replacing the whole Drive
the thing your holding (in its entirety ).
Lemwolf
8 (0.00/day)
So I just need to take out what's in side and put it into another drive?
dorsetknob
9,106 (1.24/day)
yes Replace the whole drive.
Lemwolf
8 (0.00/day)
Ok so if I have say another working drive in another computer I can switch the two?
dorsetknob
9,106 (1.24/day)
yes that's what i suggested earlier
Lemwolf
8 (0.00/day)
Ok thank you so much for the help.
So like you said b4 I can switch these two and the sixe won't matter?
dorsetknob
9,106 (1.24/day)
DO NOT CHANGE THE CIRCUT BOARDS
They wont be compatable with drive parameters/firmware
785 (0.22/day)
System Name Fat NCASE
Processor Ryzen R9 3900X
Motherboard ASUS TUF GAMING B550M ZAKU (WIFI) Edition
Cooling Scythe Fuma with 3 SCYTHE Wondersnail 2400RPM + Arctic MX2
Memory Corsair Vengeance 128GB @3200Mhz Cl16 (32GB X 4)
Video Card(s) Palit RTX 3060 StormX ITX 12GB
Storage MX500 4TB SATA + Toshiba MG08 16TB HDD
Display(s) LG 27UL500 4K monitor
Case Jonsbo W2 black
Audio Device(s) Onboard realtek 1200 & Soundblaster G3 usb
Power Supply ASUS ROG STRIX 850W Gundam Edition
Mouse Elecom wireless mouse :)
Keyboard RK100 Royal Kludge
Software Windows 10 HOME
Benchmark Scores Don't know any benchmark. It runs good enough for me.
It probably a burn out circuit board happens to my seagate too, not sure how that happen it was a perfectly working drive in storage ever since then.
If you value your data your only option left is a data recovery specialist unfortunately
DO NOT OPEN THE HDD UP. And do not swap circuit boards even for the same exact model of drive. It is not straightforward like that.
Deleted member 191766
I have a Seagate external hard drive 1500 Gbytes and it used to be in a case. The other day I noticed the power button wouldn't come on, even after switching cables etc. So I removed it from the case and tried to hook it up to my computer. After I hooked it up I noticed my computer wouldn't turn on. So I removed the drive and my computer came back on. So I tried another computer same thing. Ok so today tried it with a docking station and again while the harddrive is connected the power will not come on but as soon as I take it out the power on the dock returns. What could be the issue? View attachment 157276
Why have you removed the screws from the cover?
Toothless
Tech, Games, and TPU!
9,816 (2.42/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Entire drive is probably toast and there's nothing you can do to fix it. There is no PCB swapping or platter fixing. It's gone. That's it.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Those are not screw holes. Its just like that
Those are screw holes, and there should be screws in them.
Also, the drive is dead, you can see the burnt spot on the PCB. If you want your data back, send it out to a data recovery company. Otherwise, anything you try will just make things worse.
Lemwolf
8 (0.00/day)
Weird I didn't see any screws. Thank you all Im try to find something near by
