Second Monitor is Magnifying Contents Dragged Over?
70 (0.02/day)
Processor i5-6600k (4.2 GHz)
Motherboard Asus Z170-P D3
Memory Crucial 16GB DDR3L 1600MHz
Video Card(s) GTX 970
Storage Samsung 850 Pro
Display(s) Philips 272G5DYEB + Samsung LED HDTV
Case Cooler Master HAF 912
Power Supply Corsair 700W
Software Windows 8.1 64 Bit
I tried Googling this and didn't really see anything helpful, a number of people said the resolution for the second monitor was wrong but I don't think that's the case. When dragging a window over, before it gets half way and magnifies, it seems like the appropriate size/resolution. Everything was working fine last week when I was using Windows 10, I've since reverted back to 8.1 this week so I'm thinking there's a setting somewhere I need to toy with. Any suggestions? I've used 8.1 in the past with these two screens and didn't have any problems then. Thanks.
1,487 (0.31/day)
Anchorage Alaska
System Name Matter's / Helios 300 Predator
Processor Ryzen 7 2700 / i7 7700HQ
Motherboard B450 Tomahawk / Acer Helios 300 Predator
Cooling Arctic Freezer eSports Duo
Memory Patriot Viper ddr4 32gb / 32gb gskill ddr4
Video Card(s) MSI RTX 2080 Super Ventus OC / GTX 1060 6gb
Storage Patriot Viper nvme M2, crucial MX300 275gb, Samsung 860 qvo 1tb
Display(s) Acer 24" 1080p / 15.6 1080p HD
Case Antec 300 / Acer Helios 300 Predator
Audio Device(s) On Board - Steel Series Arctis Pro Wireless Cans
Power Supply Antec 850watt high current pro
Mouse Steel series Rival 600
Keyboard Corsair K70 / Acer Helios 300 Predator
Software Win 10 Pro / Win 10 Home
are both screens the same resolution? extend display option under display tab in control panel. could be a scaling issue too, under display tab once again or Nvidia control panel.
70 (0.02/day)
Yes both screens are 1920x1080. Here are two images I just took to show what is happening:
http://imgur.com/a/TTAPJ
If I don't drag too far, before it magnifies you can see that the window looks normal on the second screen. After being dragged far enough it magnifies, and you can see the magnification happening even on the first screen. The red lines I drew to show the divide between the two screens.
Oddly, the second screen isn't showing up in the Change Resolution/Set up multiple displays in nVidia Control Panel, but it does show up fine in the Windows "Screen Resolution" window when right clicking the desktop.
1,487 (0.31/day)
Anchorage Alaska
idk did you happen to bump ctrl + on that second screen? You might have zoomed in with the second screen. Try ctrl - to zoom out until he look the same. It is probably a setting, large font or zoomed in for that screen. If it worked before then one day it is changed, it very well could be a setting or zoom.
70 (0.02/day)
Okay so I found the culprit.
There's some odd behavior here, I think "Let me choose one scaling level for all my displays" should have been checked, and since it wasn't there were scaling differently. Leaving it on smaller keeps it consistent and it's no longer scaling when dragging to the second screen, and the primary display looks how I want it to.
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.34/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
Was about to suggest that. That's the DPI setting and it clearly looks like it got set to something larger on your second display. The reason why they allow this is, for example, when one of the screens is a 5K professional monitor (e.g. 20ish inches). If the DPI setting wasn't changed, the print would be so tiny you'd need a magnifying lens to see it.
