- Aug 12, 2013
- 55 (0.01/day)
System Name | Nebula |
Processor | Ryzen 9 7900 @5.4 GHZ |
Motherboard | Gigabyte B650 GAMING X AX |
Cooling | Custom Loop - Bykski 60mm x360 mm RAD + Byskski 45x360 mm RAD+ Barrow 30x360mm RAD + D5 Pump+Res |
Memory | TEAMGROUP T-Force Vulcan Alpha DDR5 Ram 32GB Kit (2x16GB) 6000MHz RED |
Video Card(s) | Asus Strix OC 3080 12G on Phanteks Glacier Chrome Waterblock |
Storage | Adata XPG S40G 1TB, Crucial MX500 1TB, WD SN 570 1TB , Seagate Barracuda 2TB |
Display(s) | Acer XV272U 2560x1440 @144Hz |
Case | PC O11 Dynamic White, with Custom Front Fan Mod Total 13 Fans |
Power Supply | Phanteks Revolt Pro 850W |
Mouse | Cooler Master MM720 |
Software | Win 11 Pro |
Benchmark Scores | R23 Multi: 30K CPUZ Multi: 12450 |
I have a simple question: What values one should change in bios to match CAS timings to avoid latency errors If using different modules or RAM. i know mixing Modules isn't a good idea but see at times we have to improvise ..
I have kingston hyper x blu 1600 mhz 4x2 gb, i bought 4x2gb fury as blu model is no longer available, i see both can run at same frequency by default 1600MHz but has latency matching issues issues , by default system sets them to 11 for each,
As per specs blu is having CAS 11 by default & with xmp it turns to 9 and while fury has default only of 10 CAS respectivley.
As if both of these are having programmable CASi changed the following values in bios to match timings for each channel:
#Latency 10:
#RAS to #CAS 10:
#RAS Precharge: 10
in BIOS there are a lot of values to set but i changed only theses, so for i just wanted
to confirm that i did it right as i was not able to find any tutorial for it, ihave a z87 MSI Mbd.
Pls post any good video tutorial for the same.
If it is wrong so should i leave it set as default??
#Latency 10:
#RAS to #CAS 10:
#RAS Precharge: 10
