- Apr 29, 2006
- 5,105 (0.73/day)
- Sydney, Australia
System Name | UltraPC |
Processor | E8500 Core 2 Duo, 1333Mhz FSB, 3.16Ghz @ 4.5GHz (got into Windows @ 4.75GHz) |
Motherboard | ASUS P5Q-e |
Cooling | CPU Cooler - TT V14 Pro, 2x120mm CM Blue LED fans, 1x90mm CM Blue LED fan |
Memory | G.Skill Pi 4GB (2x2GB) Dual Channel DDR2 PC8000 (1000MHz), 5-5-5-15 |
Video Card(s) | Sapphire HD4850 512mb with ASUS EAH4850 BIOS |
Storage | 2x 500GB Seagate 7200.12 Raid 0 |
Display(s) | Acer AL1912, 19" LCD screen |
Case | Thermaltake Soprano Black ATX case |
Audio Device(s) | Onboard 7.1, Speakers - 5 + Sub + Monitor speakers |
Power Supply | Thermaltake 850W Toughpower Cable Management - Quad (2x18A and 2x30A) 12V rails |
Software | Win 7 Pro x64, MSN, CS:Source, etc etc |
On my server (in sig), I want to set it up so it is in standby all the time until something wants to access it over the network (eg, someone chooses remote desktop to connect to it, someone goes to access a file on it over the network, someone goes to print (printer hooked up to server), someone connects to vent server on it (got a full time ventrilo server running on it) ....etc.)
Currently it is on full time. Its not a problem as it doesnt use much power...but for the little use the server gets (ie, gets sent back up once a day), its not worth staying on all day and all night.
Is this in any way possible?
The computer has a WOL jumper for a cable, but I dont know how that works. Also as shown I have a PCI gigabit card attached, to which I am not sure if there is a WOL jumper on it (and I dont use onboard LAN, only the gbit lan card).
Thx
Thx
