- Feb 28, 2024
- 10 (0.02/day)
Processor | AMD Ryzen 5 7600X 6-Core |
Motherboard | MSI MAG B650 Tomahawk WiFi |
Cooling | Thermalright Peerless Assassin 120 SE |
Memory | G.SKILL Flare X5 DDR5 32gb (16gb x2) |
Video Card(s) | PNY GeForce RTX™ 4070 Ti Super 16GB |
Storage | Silicon Power 2tb NVMe |
Display(s) | 2x Gigabyte M27Q X 27" 240Hz 1440P |
Case | DeepCool CG650 Mid-Tower |
Audio Device(s) | SteelSeries Arena 3 2.0 Speakers |
Power Supply | Corsair RM750e |
Mouse | Razer Viper V2 Pro |
Keyboard | NuPhy Halo65 |
Hey all. I've been troubleshooting this problem for around 2 weeks, and have not been able to fix it. It's really bumming me out to have a brand new PC that should be making gaming a blast, but to have spent the majority of my time with it so far trying to fix these problems.
Every day since I've had it, I've had intermittent issues with mild to severe lag during both normal desktop functions as well as during gaming. When gaming, it's prior to any online play, so the internet speed shouldn't be a factor I'm assuming. When I launch a more graphically demanding game (Helldivers 2, for example), it either runs smooth like butter or so slow that I have to hold inputs to get them to register for things like the start menu to pop up. The fact that it will play like nothing's wrong occasionally but like the PC isn't powerful enough to handle the game other times is what confuses the hell out of me.
I've also had a lingering issue with audio, where it will distort and crackle. This mostly occurred through my TV speakers (which would work fine with the consoles hooked up to it), and then would be totally normal without any distortion through my headset. However, I've had a couple times recently that the audio has still been messed up through my standalone speakers.
The problems seem to get significantly worse after the PC has been in sleep mode and tries to wake up, but this isn’t consistent.
I have tried the following:
-Swapping out the TV I had been using as a display (TCL 29hz and no drivers to help it) to a 1440p 144hz monitor with drivers
-Adding standalone speakers to my setup instead of using the TV speakers
-Updating everything that I know of (monitor driver, AMD Adrenalin drivers, motherboard drivers, Windows Updates)
-Clean booting
-Unplugging and replugging HDMI cable
-Check the Task Manager for performance, where everything has always been in a normal range whether I'm experiencing the issues or not
-Power cycling
-Restarting ad nauseum
-Leaving the PC off for awhile before using it
Things I'm planning to do:
-Reseat the GPU
-Swap to Display Port cables instead of HDMI
-Take pictures of the PC as the guide suggested, when I'm doing the other steps so I have decent lighting
I am at a loss, especially since it sometimes decides to function normally when I haven't taken any new steps to fix it, or when I haven't done anything at all. I have never had this much trouble with a PC, either custom or pre-built, and I just want to get these issues fixed ASAP. I'm wondering if it could be a Windows driver issue, or maybe something that didn't get connected correctly during the build. Any and all help is HUGELY appreciated, thank you!
-Clean booting
-Power cycling
-Reseat the GPU
