Show System Time as Sensor
SuneJorgensen
2 (0.00/day)
Would it not be possible and quite easy to add a new sensor showing the system time (same as shown in the log file).
This way one would know the value of the common time axis for all the other sensor values.
Absolutely, more a workaround than a proper solution though.
I've always wanted to rework the sensors interface, but seems it's impossible to find the time
How would that fit into the tiny vertical space available?! Not sure how this will work, unless a major reworking is done.
The graph is not relevanl, only the number shown when you move the mouse, and will not require any new functionality.
Not optimal when you only can see the y- value and not the x-value, and time is just another number.
There are many better ways to do it, but will require more than 5 min to implement, time the dev do not have, therefor my suggestion.
