- Oct 9, 2007
- 47,769 (7.42/day)
- Dublin, Ireland
System Name | RBMK-1000 |
Memory | 2x 16GB DDR4-3200 |
Storage | Samsung 990 1TB |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
SilverStone brought a host of new AIO liquid CPU coolers to Computex 2025, and we begin our tour with the IceMyst Pro line of AIO CLCs for a wide range of gaming desktop CPU socket types. The company also added support for AMD Socket TR5 for Ryzen Threadripper HEDT processors. These coolers come in 240 mm, 280 mm, 360 mm, and 420 mm sizes. Next up are the IceMyst 2U and 3U lines of AIO CLCs for rackmount cases. These are highly socket specific. The IceMyst 400 2U comes with a pump-block that supports LGA1851 and AM5, with the included 80 mm server-grade fans turning at speeds of up to 8,000 RPM to push air through radiators that are either 400 mm x 80 mm (5x 80 mm), or 240 mm x 80 mm (3x 80 mm). Then there's the 3U-capable XE360PD, which comes with a pump located in the radiator, and a water block that's capable of AMD Socket TR5; and the XE360PDD, which is meant for 2P servers and workstations. There will be models specific to CPU socket types, including SP5 and LGA4266.
More pictures follow.
