Silverstone Raven RV01
71 (0.01/day)
Processor Intel Core I7 4820K 4.6GHz
Motherboard Asus P9X79 WS
Cooling Corsair H90
Memory 16GB G.Skill Sniper 1866MHz
Video Card(s) MSI 4G Gaming GTX 970 SLi
Storage Intel SSD 320 Series 120GB, 1 Samsung EVO 1TB, 1 Samsung EVO 750GB
Display(s) BenQ XL2720T 120hz
Case Fractal Design RL2
Audio Device(s) Creative SoundBlaster Z
Power Supply EVGA SuperNova 1300 Watt G2
Software Windows 8.1 Pro 64
Case upgrade time!
Retiring the old Antec 900 (first revision), and replacing it with the Silverstone Raven RV01.
Initial impressions of the Raven is, omg its MASSIVE! For perspective I could sit in the box in came in (6'4" 200lb guy) haha. Installing my hardware into this case was incredibly easy, as was cable management. Attempting to hide cables on my old Antec 900 was a nightmare heh.
My one fear with buying this case was that the case only has 1 120mm fan for outtake. Since I use a Corsair H50 CPU cooler I feared using it would block hot air escaping the system. After I installed my H50 cooler I noticed that it really wasnt restricting too much air exiting the case and installing a second fan on the radiator (push/pull config) solved the issue.
I read in reviews that the front door can be noisy when opening and closing. I found this to be true but you have to ask yourself, how many times do you use a DVD drive in a year? My answer: maybe once when reinstalling windows, heh.
Enough talk, time for some pictures
Finally, the most important part, temps!
Room temperature was 22C
Really happy with this case.
734 (0.12/day)
Golden, Colorado
System Name KAREN / EVA / GHOST
Processor Intel Core i7-950 / AMD Phenom II X4 940 BE / Core i5 3570k
Motherboard ASUS TUF Sabertooth X58 / DFI LP DK 790FXB-M2RSH / Asrock z77e-itx
Cooling Thermaltake Frio / Corsair Cooling™ Hydro Series H50 / Corsair Hydro Series H60
Memory Corsair Dominator 6GB DDR3 1600 / Corsair Dominator Quad2X4096-8500C5DF / G.SKILL Ripjaws Serie 1600
Video Card(s) XFX HD6950 CF unlocked /XFX HD5770 CF/ MSI R4890 Cyclone
Storage OCZ Vertex 2 60 WD Raptor X WD1500AHFD / Seagate Barracuda /Western Digital 80gb, Toshiba 1TB
Display(s) 2 Acer P215H 21.5 Widescreen / Acer S211HL 21.5 / HP 2009F 20inch
Case SILVERSTONE RAVEN RV02-BW / NZXT Phantom /Bitfenix Prodigy
Audio Device(s) On board / Philips MMS 321 - PC multimedia speakers
Power Supply Ultra X3 ULT40311 1000W / Cosair CMPSU-750TX 750W/ CORSAIR Gaming Series GS700 700W
Software Windows 7 64 bit / Windows 7 64 bit / Windows 7 64 bit
I also upgraded my case from the Antec 900 to the Silverstone Raven 2. I love the case but my temps are not as good as the 900. The 900 to me was a beast for cooling I was just searching the threads and saw you had it also. Did your temps get better or are they about the same.
Room temp 21.5c
jrgerryd
25 (0.00/day)
philippines
really nice, i'm lovi'n it.. i wish i have some of that.
