Smart Gart Woes
confused
16 (0.00/day)
I have an ATI 9800 pro video card. When i enter the advanced video settings menu's and select Smart Gart, my AGP settings are set to off. 4x and 8x are available to choose. I obviosly want to choose 8x, so i do. an info box pops up and tells me to restart the pc. No problem right, wrong.
After restart i go back to that screen and lo and behold my agp is set to off again. Now it says that it automatically chooses the most stable setting, but how can off be the most stable setting.
How is this affecting my video card performance? or does it?
P.S. I viewed my system specs using SANDRA and current agp settings show up as blank. oh and by the way 4x dosn't work either.
Well if its resetting the agp, it must be unstable. I shouldn't be though. Try reinstalling your drivers. Without having agp, you might as well have pci video card. It will effect the transfer rate between the card and the rest of the pc so it will slow you down. So try cleaning off your drivers then reinstall. You might have to disable fast writes aswell to have the agp.
-Dan
check bios for agp 8x enabled and it isnt a problem if you have 4x or 8x it runs at same speed
i have reinstalled the drivers for both the video card and the mother board with no luck. now what?
I have also checked my bios and 8x is enabled
If fast write is on turn it off and try the AGP agian.
-Dan
hm probalby a windows thing i have had same prob but hte only thing that helps there was windows reinstalling.
do u have sp2?
What os are you using and what version of cat do you have?
-Dan
fast write is already off
i have win xp sp1. (i wont install sp2 the firewall notifications bug the hell out of me.).
Do you really think i have to reinstall windows?
i am using the latest omega drivers not catalyst.
AMD athalon 2500+ barton
512 meg ram
ati 9800 pro 128meg
nforce2 chipset
You can disable the fire wall if you want. You might have to reinstall windows. But see if you can try the card in another computer first. If you have the same problem then its the card if not you have to reinstall or search for the problem in windows.
-Dan
No friends that will let you use their computers? But doing windows should fix it if its software.
-Dan
well after a few hours of reinstalling windows and all those annoying little cracked programs :) . i can happily report that it has fixed my problems. SMARTGART is working properly. YAY thanks for all the help.
My video performance has greatly increased too. im up 400 points on 3dmark 03. :D
lol...a expert...well I wouldn't say that, but I just read a lot and play with them. I am only 16 and I tend to get very boarded sometimes so, I read or tinker. :D Thanks dude. ;)
-Dan
