SMBus controller
Demos_sav
870 (0.13/day)
Cyprus
Processor Intel P4 519K LGA775 3.06GHz @ 3.82GHz
Motherboard ASUS P5WD2
Cooling Arctic Cooling Freezer 7 Pro
Memory 3GB Kingston Hyper-X DDR2 3-4-3-6 @667MHz
Video Card(s) XFX 8800 GTS 320MB XXX Edition @ 630/970
Storage Samsung 160GB SATA2 7200RPM 8MB
Display(s) SONY SDM HS75 17' LCD
Case Interset (black)
Audio Device(s) Realtek HD ALC882 8-channel onboard
Power Supply Thermaltake Toughpower 750W
Software Windows XP Home edition 32bit fully tuned
Benchmark Scores 3dm01-29689 3dm03-31099 3dm05-10298 3dm06-6409
I checked my bios's settings and i found that SMBus controller is disabled. Is that good or bad? Should i enable it? What is SMBus and what does it do exactly?:confused:
Needs to be enabled, it's fairly important! its the System Management Bus and processes mainly low level information on the motherboard, a breif description is:
The System Management Bus (abbreviated to SMBus or SMB) is a simple two-wire bus used for communication with low-bandwidth devices on a motherboard, especially power related chips such as a laptop's rechargeable battery subsystem (see Smart Battery Data). Other devices might include temperature sensors and lid switches.
A device can provide manufacturer information, indicate its model/part number, save its state for a suspend event, report different types of errors, accept control parameters, and return status. The SMBus is generally not user configurable or accessible.
The bus was defined by Intel in 1995. It carries clock, data, and instructions and is based on Philips' I²C serial bus protocol. Its clock frequency range is 10 kHz to 100 kHz. Its voltage levels are different from those of I²C, but devices belonging to the two systems are often successfully mixed on the same bus. The SMBus has an extra optional signal called ALERT#, which can be used by slaves to send an interrupt request to the controller.
Linux, Windows 2000, and Windows XP support SMBus devices, but Windows 98 does not.
It also has linkage to the Mobo BIOS and other stuff, if you wanna be a real swot readthis link talking about its functions in relation to Mobo/BIOS processes.
http://www.sbs-forum.org/marcom/sbexpo_feb02/01 SBD Access under ACPI.PDF#search="smbus driver"
I found some other options disabled too. Should i enable any of those too?
Here is the list
Dara execution prevention
Runtime Power Management
ACPI S3 Hard disk reset
SATA Power management
Post messages
Limit CPUID Maximum value to 3
PCI VGA Palette snooping
Unique sleep state blink rates
Monitor Tracking
All the above are disabled. Should i enable any of those?
