socket 478 motherboard
Demos_sav
870 (0.13/day)
Cyprus
Processor Intel P4 519K LGA775 3.06GHz @ 3.82GHz
Motherboard ASUS P5WD2
Cooling Arctic Cooling Freezer 7 Pro
Memory 3GB Kingston Hyper-X DDR2 3-4-3-6 @667MHz
Video Card(s) XFX 8800 GTS 320MB XXX Edition @ 630/970
Storage Samsung 160GB SATA2 7200RPM 8MB
Display(s) SONY SDM HS75 17' LCD
Case Interset (black)
Audio Device(s) Realtek HD ALC882 8-channel onboard
Power Supply Thermaltake Toughpower 750W
Software Windows XP Home edition 32bit fully tuned
Benchmark Scores 3dm01-29689 3dm03-31099 3dm05-10298 3dm06-6409
Which is the best motherboard for P4 s478? It has to be the best overclocker. I wouldn't mind having AGP but I would prefer PCI-E. I don't mind if it has DDR or DDR2 but the second is more preferred. I don't care about any other extras.:o
The best overclocking motherboards for skt478 use AGP and DDR and you can only find them used these days. You don't really need DDR2 in an older skt478 it's not worth the upgrade. My computer scores higher in sciencemark that my brother's even though he has DDR2 and I don't. Looking around I don't see many new skt478 motherboards that I would even consider buying.
See if you can find one of these on e-bay
Abit IC7
Asus P4C800 Deluxe
Asus P4P800 Deluxe
MSI 875P NEO-FIS2R
MSI 865PE Neo2 Platinum
Abit IC7
Asus P4C800 Deluxe
Asus P4P800 Deluxe
MSI 875P NEO-FIS2R
Thank you!!:toast: :D
This is what I have and it works great. I can get a stable 3.8Ghz (1000Mhz FSB) overclock without any problem.
I got my 3Ghz Prescot (478) up to 4.1Ghz on a P4P800-SE :)
you canstill s478 mobo's new from places like ur local pc shop mine sell asus,and asrock mobos still,look for mb820 industrial boards u can still buy those and they overclock apparently
the MSI mobos are solid but usually limited in terms of top end FSB overclocks compared to the ASUS boards
