lyndonguitar
I play games
- Apr 1, 2010
- 1,878 (0.34/day)
- Philippines
System Name | X6 | Lyndon-ROG |
Processor | Intel Core i7-8700k | Intel Core i7 6700HQ |
Motherboard | Gigabyte Z370 Aorus Gaming 5 | Asus ROG-GL552VX |
Cooling | Deepcool Captain 240EX |
Memory | 16GB Corsair Vengeance LED | 8 GB |
Video Card(s) | NVIDIA GTX 1080 8 GB GDDR5X | NVIDIA GeForce GTX 950M 4GB |
Storage | SSDs: 500GB, HDDs: 2TB, 2TB, 3TB | SSD: 250GB, HDD: 1TB |
Display(s) | Samsung 49" CHG90 3840x1080@144Hz, Panasonic 32" HDTV, | 15.6"1080p |
Case | Cougar Panzer Max |
Audio Device(s) | HyperX Cloud II | Corsair Gaming H1500 7.1 | ROCCAT Kave 5.1 | Edifier M3200 |
Power Supply | EVGA 750GQ |
Mouse | Logitech G403 | Razer Deathadder Chroma | Logitech G302 | Mad Catz Cyborg R.A.T. 5 |
Keyboard | Corsair Vengeance K70 Cherry MX Red |
Software | Windows 10 |
I have an Z370 Aorus gaming 5 and an intel core 8700k. I kinda followed this Guide in overclocking. and this
the only difference is that I started from lower multipliers and voltages. However my problem is that once I try to overclock(set multiplier to 45, 46, 47, etc). it displays the correct freqs in the BIOS, with correct voltages and normal temps, but in windows(Cpu-Z, task manager) At startup it displays the correct freq for a few seconds then forever locks at 4.3GHz. it just sits at 4.3GHz all cores. Sometimes it will luck out and stays at the target frequency e.g. 4.8GHz (with normal temps)
I thought it's throttling but the temps are good, and it's just idle anyway. I checked power options, max processor is set to 100%. Any ideas what might be causing this?
