[Solved] Xbox 360 wireless receiver software problems
Status
Not open for further replies.
lyndonguitar
I play games
1,878 (0.34/day)
Philippines
System Name X6 | Lyndon-ROG
Processor Intel Core i7-8700k | Intel Core i7 6700HQ
Motherboard Gigabyte Z370 Aorus Gaming 5 | Asus ROG-GL552VX
Cooling Deepcool Captain 240EX
Memory 16GB Corsair Vengeance LED | 8 GB
Video Card(s) NVIDIA GTX 1080 8 GB GDDR5X | NVIDIA GeForce GTX 950M 4GB
Storage SSDs: 500GB, HDDs: 2TB, 2TB, 3TB | SSD: 250GB, HDD: 1TB
Display(s) Samsung 49" CHG90 3840x1080@144Hz, Panasonic 32" HDTV, | 15.6"1080p
Case Cougar Panzer Max
Audio Device(s) HyperX Cloud II | Corsair Gaming H1500 7.1 | ROCCAT Kave 5.1 | Edifier M3200
Power Supply EVGA 750GQ
Mouse Logitech G403 | Razer Deathadder Chroma | Logitech G302 | Mad Catz Cyborg R.A.T. 5
Keyboard Corsair Vengeance K70 Cherry MX Red
I have the latest version of Windows 10, I have a problem with the wireless receiver for xbox 360 controllers. it is a software is afaik, because the receiver and the controllers works fine with my laptop. I have 2 receivers and many controllers and they work fine with my laptop(windows 10 latest as well)
Whenever I startup the computer, the first 'connection' of the controller works. USB plugged in sound can be heard when I first start the controller. then I turn the controller off, the USB removed device will be heard. I can game just fine. the controller works as intended
Now this is where the problem happens. I turn on my Xbox 360 controller again(for the second,third, fourth time, etc). It syncs with the receiver. but windows 10 does not detect it anymore, theres no USB plugged in/removed sound as well if I try to turn it on and off.
The only way I could make windows 10 detect the controller again is by signing out and singing in again, or restarting the computer. so the receiver works on the First instance... once the controller turns off, I have to restart the PC to make it work
Replugging the wireless receiver works as well, but the controller now moves to player 2, then player 3 on the second replug, and so on
EDIT: I suspect some kind of USB/power problem. I have yet to discover the cause.
I tried unchecking the power down device when not in use settings in device manager, does not work, tried a whole lot of BIOS settings, even reset it to defaults, no avail. Tried different ports as well, USB 2, 3, doesnt work. reinstall different xbox 360 receiver drivers, installed the same drivers as the laptop im using, still not working
Update: somehow fixed itself. I've been trying all day to fix it. suddenly it got fixed. I dunno what I changed. last thing I did was to just reset the BIOS and then returned the settings back(to what I liked), but I did reset the BIOS earlier and it didn't work earlier
Found the culprit. It was the SelLedV2 program(RGB Fusion from Gigabyte) that is interfering with my Receiver. as soon as I close it it instantly fixes the problem. weird
Glad you solved it.:)
You could add [Solved] to the thread title.
Status
