Sony PS1 Emulator PS1 Controller
137 (0.05/day)
System Name Windows 10 Pro x64
Processor Intel Core i5-4670K@4200 MHz
Motherboard ASUS Z87-PRO
Memory Corsair XMS3 4x2 GB 1600 MHz
Video Card(s) ASUS GeForce GTX 1060 6GB
Storage SSD SAMSUNG 840 EVO 250 GB, SSD SAMSUNG 850 EVO 250 GB, 3x WD Blue 1 TB
I can't set my Sony PS1 Controller in ePSXe. I'm using PSX/PS2 adapter for PC.
137 (0.05/day)
Axes not even work in controller settings in Windows 10. PS2 controller works.
I tried different PS1 Controller and it's not working too.
I tried on other computer with Windows 7 and it's not working.
3,152 (0.90/day)
Argentina
System Name Ciel / Akane
Keyboard VSG Alnilam / Dell
Bad adapter or bad drivers.
30,498 (7.07/day)
Try to find different or more current drivers. If that doesn't work, the adapter itself might be bad.
137 (0.05/day)
But red LED light works on Sony PS1 Controller.
OneMoar
There is Always Moar
8,834 (1.61/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
get a ps3/ps4 controller those will work better
those controller adapters are not compatible with most newer os's
137 (0.05/day)
But my Sony PS4 controller doesn't work with bluetooth dongle. Maybe because Windows 10? It connects and disconnect. When i launch game PS4 controller doesn't work anymore.
OneMoar
8,834 (1.61/day)
Rochester area
use this program
http://ds4windows.com/
you can either connect via usb or bt follow the programs instructions
137 (0.05/day)
I have this program. When i launch any game controller stopped working.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Then just use the PS2 controller. They are basically the same controller anyway.
You can use it plugged in with a USB cable. You don't need to connect it through Bluetooth.
137 (0.05/day)
It's bad adapter. I tried in Windows 8.1 in VMware Workstation (fresh install) and Sony PS1 Controller not working too.
I'm thinking to buy another Xbox One Controller S only for PC. I have one but i'm using on Xbox One console.
30,498 (7.07/day)
It's bad adapter. I tried in Windows 8.1 in VMware Workstation (fresh install) and Sony PS1 Controller not working too. I'm thinking to buy another Xbox One Controller S only for PC. I have one but i'm using on Xbox One console.
I have a set of WiiU controllers running through this adapter;
https://www.amazon.com/Mayflash-Wireless-Wii-Controller-Adapter/dp/B00E6553PW
And these are the controllers;
https://www.amazon.com/NEXiLUX-Wireless-Controller-Gamepad-Nintendo/dp/B018IZLF66
All work perfectly and for the same price you pay for one XBox controller you can get this adapter and two controllers. Any WiiU controller will work though.
