- Nov 30, 2015
- 712 (0.21/day)
- Croatia
Processor | Ryzen 5 3600 PRO |
Motherboard | AsRock B450 Pro4 |
Cooling | Thermalright Peerless Assassin 120 |
Memory | Silicon Power XPower Zenith 2x8GB @3200 MHz |
Video Card(s) | Gigabyte RTX 2070 Super Gaming OC 8GB |
Storage | Crucial P5 Plus 1TB / Crucial MX 500 1TB |
Display(s) | Dell P2419H |
Case | Fractal Design Pop Air /w 3x Thermalright TL-C12C |
Audio Device(s) | Creative Sound Blaster Z + Edifier R1000T4 |
Power Supply | Super Flower Leadex III 650W |
Mouse | Microsoft Intelimouse Pro |
Keyboard | IBM KB-8926 |
Software | Windows 10 Pro 64-bit |
Benchmark Scores | Turns on on the first try! Usually. |
So I've been looking into upgrading my speakers somewhat. Right now I have a cheap 2.0 set that works just enough for my needs, some gaming and music listening.
I am by no means a sound snob and personally cannot tell the difference between decent 320kbps MP3s and flac audio.
I plan to buy the Edifier R1280T speaker set in the near future and I've been wondering whether I should upgrade my soundcard as well. As a budget upgrade, I've seen people recommending cheaper sound cards tho some suggested to stick with the onboard stuff if the speakers are not really high-end. Right now I can get a Xonar DGX for a reasonable price but I figured I'd hold off buying it if it is not necessary, if the onboard will do the job that is.
Currently, the board I'm using has a Realtek ALC887 codec and from the motherboard review on here this implementation a got decent review on that part.
So, yay or nay on the sound card upgrade, and if yes do you have any (budget oriented) recommendations?
