Sound Cards and Linux
Cold Storm
Battosai
15,010 (2.33/day)
In a library somewhere on this earth
System Name Haro
Processor AMD 1700x
Motherboard AsRork x370 Taichi
Cooling EK Custom Loop - CPU only
Memory 32gb G-Skill Trident Z
Video Card(s) EVGA 1080 Superclock 2
Storage Too Many
Display(s) Viewsonic VX2450WM-LED 24" & LG 32 IPS
Case Cooler Master Cosmos II
Mouse SteelSeries Rival 500
Software Win10 Pro
Benchmark Scores i5 750 4.62ghz pi runs // Evga FTW p55
Hey guys. I'm new with the use of Linux but I have something to ask..
Is there anything that is needed, if the company only supplys windows base drivers, do I need if I have say a HT Omega Claro Halo card?
Meaning: I'm wanting to use the ^ card in linux but don't know if it's going to work or not.
Note* I'll know in a bit on what version of Linux since I'm not sure.
need linux version (kernal version if you have it) and sound card model/version.
alot of things work out of box with modern linux much like modern windows but wont have full functionality.
Thanks for the help yogurt. I don't know my sound cards version, but it's a
HT Omega Claro Halo XT... Which is really just a HT Omega Claro Halo card. Just that it has a extended board for the 7.1 sound rca jacks.
You can just use trial and error method. Boot from any Linux live cd (it means you don't have to install it and it also won't screw your current OS and see will it work there).
It's what I would do. Then you know how much of an issue it really is.
Basic sound usually works good but if you want to play around with settings etc it gets hairier and that I don't know what to do.
I actually had the same problem. I would consider myself a seasoned Linux user and I couldn't figure it out. I haven't tried any kernel >=3.1, so perhaps they fixed something that I missed in that timeframe?
I know Ubuntu 11.04 and 11.10 ran right out the box with no added drivers with my Sb audigy platinum.
Ubuntu 11.10 worked right out the box for the halo claro for me. So go ahead and do eet! For some reason it sounds better in linux then in windows for me.. Must be the drivers or some setting. More OMMPH!
