- Jan 6, 2008
- 3,521 (0.55/day)
System Name | Xazax |
Processor | 6700k |
Motherboard | ASrock Fatal1ty z170 |
Cooling | H240X |
Memory | 16GB DDR4 2800mhz |
Video Card(s) | Gtx 980ti |
Storage | 1TB Mushkin |
Display(s) | ASUS PG27 G-sync |
Case | Corsair Air 540 |
Audio Device(s) | Logitech G35 |
Power Supply | Corsair 1500w Digital |
Keyboard | Patriot Viper |
Software | Windows 10 |
So, im using an Xonar D2 with Vista Ulimate fine for a couple of days with my new computer. I dont have any issues with my 5.1 sound system(Logitech Z-5500) and everything is going great. Then one day i decide to install and play Rome:Total war for some nostalgia and while it was installing i was playing some music(megadeth) in the background... well once it finish i opened up RTW went into Audio/Graphics and changed everything how i wanted it. Now when i got to the sound as my XONAR D2 is able to do EAX 2 within Vista i enable it with no problems however when i do so i noticed i no longer get sound out of my Right Front speaker. Well screwing around for hours on end trying to get it to work, i uninstall and reinstall XONAR drivers and no avail, At one point i did get sound out of all five when restarting my computer however changing the Audio Output(2/4/6/8 channels) would mess it up again. Fustrated i decided to install an Sound Blaster Augidy SE thinking it had to be the XONAR, well it wasnt because i still didnt get sound out of my right front speaker, when the SE was install and put to 5.1. Now its even worse! the speakers change everytime at random, meaning when i i click "test" sometimes ill hear the Right front come out of the center! or the Left Front being the Right rear! then when i do the test again this time the Right front works correctly and the Right Rear but i get the Center out of the left front!
What the hell happened! I've tried about everything i can think of and my last resort is to install Vista again(this time without RTW!) i personally believe something got screwed up in vista but if so, how do i fix it? i mean i have no idea what the hell it could be.
Any help, because im on my last straw and my HDD is going to be wiped.
:shadedshu
EDIT: PROBLEM SOLVED IM RETARDED THANKS FOR ALL THE HELP.
i must of messed up the wiring to the sound card, the Right Front and the Subwoofer were switched and i put them back now i get my sound again.
