- Feb 18, 2011
- 1,452 (0.28/day)
- Romania
Processor | Ryzen 5700x |
Motherboard | MSI B350 Gaming Pro Carbon |
Cooling | be quiet dark rock pro 3 |
Memory | GSKill Aegis 32GB (4x8GB) DDR4 3200MHz CL16 |
Video Card(s) | PowerColor Radeon RX 7800 XT Hellhound 16GB GDDR6 256-bit |
Storage | Seagate Barracuda SATA-II 1TB , HyperX Savage 240GB SATA 3 |
Display(s) | Benq EX2780Q |
Case | Be Quiet! Dark Base Pro 900 |
Audio Device(s) | Sound BlasterX G6 |
Power Supply | Seasonic prime TX-650 |
Mouse | Marvo Scorpion G981 |
Keyboard | Razer Blackwidow Elite - Yellow Switch |
Software | Windows 10 Pro |
I need this. But it is safe to use it ?
I have a 5.1 sound system. There are moments when I need to use my headsets with microphone incorporated for gaming and recording purposes.
I need to take out the front speaker cable jack from the computers sound card and insert my headsets.
With this I can have both speakers and headset connected at all time. The idea would be not to damage the sound card from all the switching between the cables. Inside it has 2 metal clamps that contact with the jack. Those clamps (as I call them) in time will be more lose and won't provide contact. I had it happen to other devices many times. Would it happen in 2 years or 3 or 6 months no one knows.
My question is , how safe is this method ? Considering I am adding electric current impedance on the same line. At the end inside the sound card there is a resistance. That resistance can fail, as it has done so before on my old boom-box when I added two strong speakers on the same line.
P.S. : I know i did it before and it failed, however this time maybe the headsets are not as strong as the speakers I used in the past ? I don't know.... What are you thoughts on this what are your thoughts on this
I could use better cables too like this (in case cable quality was a problem) : https://www.aliexpress.com/item/Ugr...f0a1-423d-bc0d-3b99512964c0&priceBeautifyAB=0
