Completely Bonkers
- Feb 6, 2007
- 2,576 (0.38/day)
Processor | Mysterious Engineering Prototype |
Motherboard | Intel 865 |
Cooling | Custom block made in workshop |
Memory | Corsair XMS 2GB |
Video Card(s) | FireGL X3-256 |
Display(s) | 1600x1200 SyncMaster x 2 = 3200x1200 |
Software | Windows 2003 |
I'm testing this piece of software I found recently. It is a DISKCACHE. All HDDs have a hardware cache, typically 8MB-32MB. Windows also has a diskcache. This is a software solution to give you a bigger cache and to cache things that windows doesnt.
How can it help? Increasing cache size increases the probability of cache hits which therefore improves effective HDD read/writes. Seek times are near-zero when the data is in the cache. More info in the link. It works based on the same principles as a ramdisk, but rather than specifying a ramdisk, it works on a dynamic data set... the data you are referencing on your HDD. Speedups for cache hits are similar to when using a ramdisk.
You can make it cache specific drives or specific partitions. Got a games partition? Or a system partition? Make it cache just that and not your data/archive/media drives.
http://www.romexsoftware.com/en-us/fancy-cache/index.html
I'm testing it. I'm a bit sceptical; especially with this funny FancyCache name. However, it is from the same people who do a pretty decent ramdisk. I guess it all depends on the efficiency/inefficiency of Windows inbuilt cache. However, it does seem to be very useful for 32-bit OS since it uses memory mapping >4GB for the cache. On the forum there is a lot of talk about speedups on virtualised systems VRM http://www.romexsoftware.com/bbs2/en-us/viewforum.php?f=23
My initial results are attached: Atom netbook SSD, with FancyCache (default settings), with ramdisk.
If you test it, pls. give feedback. This could be interesting.
