SSD benchmark settings
12 (0.00/day)
Hello guys
I have an SSD that I would like to benchmark. I had few questions on my mind about how should I go about it.
I have downloaded the following-
ATTO
CrystalMark
AS SSD
Anvil Pro
How can I assign the settings to the programs so that the trustworthy real world usage results can be obtained? I mean the QD, Block size, test file size etc..... What numbers should be assigned to them?
Also is there any other Application that I can use?
Thanks in advance
Well if you want actual real world data, the only thing you can sensibly do is using it. Windows startup times, applications/games loading times, writing/reading files in various formats/sizes... Points gained in benchmarks are only valid as comparision to other points obtained in the same benchmark.
Well if you want actual real world data, the only thing you can sensibly do is using it. Windows startup times, applications/games loading times, writing/reading files in various formats/sizes... Points gained in benchmarks are only valid as a comparison to other points obtained in the same benchmark.
Okay let's say, I don't consider the real life usage. Then what settings should be used?
I never changed anything in SSD benchmarks, just run it as default.
I think most people run it like that.
